Click for Ocean Alexander Click for Westport Click for Westport Click for Delta Click for YF Listing Service
Walker Air Seps
Discussion in 'Ocean Yacht' started by Boomer, May 18, 2018.
  1. Boomer
    Boomer Senior Member
    Seminole
    What do you clean the air seps with? Do you have to oil coat them after installing? Thanks ahead of time....
  2. MBevins
    MBevins Senior Member
    Windsor On. Canada
    They sell a kit of cleaner and oil. About $20 at most auto stores. Made and sold by airsep.
    Remove filter, laundry sink with hot water works best. Spray filter with cleaner, let stand a few minutes, rinse out with hot water. Take outside and air-dry. Then spray with oil till you have a nice evening red color.
  3. Boomer
    Seminole
    Thx
  4. Boomer
    Seminole
    Do you scrub them with a soft brush?
  5. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    I think they do 2 different kits, one with red oil, one blue. You'll have to check which oil was used previously.
  6. MBevins
    Windsor On. Canada
    Really shouldn't have to. Remember rinse from inside to the outside. All the crud is on the outside
  7. Capt Ralph
    A K&N cleaning kit works also (same filter).
    Easy on the new red oil, it could drip for weeks if over oiled.
  8. MBevins
    Windsor On. Canada
    Thanks, that's actually what I was referring to.
  9. Boomer
    Seminole
    Thank you!
  10. bsd222
    bsd222 New Member
    new orleans
    Just installed new Walker Seps, do I need to oil new filters before use?
  11. MBevins
    Windsor On. Canada
    If they're not oiled then yes.
  12. Capt Ralph
    NO.
  13. bsd222
    bsd222 New Member
    new orleans
    thnx for the replies, checked their website under frequently asked questions. They come ready to use out of the box, only need to re-oil after cleaning
  14. Beau
    Beau Senior Member
    Beaufort, NC
    And only lightly oiled. Remember this is not a lubricant but an assist to reduce the filtration diameters, plus add a little adhesiveness to the air flow. The base oil is a thick mineral oil.
  15. Boomer
    Seminole
    Pulled the air seps...some black powder on the turbo..bad?
  16. Capt Ralph
    Normal. You can wipe off with a finger. Hopefully not gritty.
  17. Boomer
    Seminole
    Nope, like talc powder...thanks
  18. Danvilletim
    Danvilletim Senior Member
    isleton, ca
    How can you tell when it's time to clean or replace?
  19. Boomer
    Seminole
    The red mesh is dirty or black?
