Click for Westport Click for JetForums Click for YF Listing Service Click for Glendinning Click for YF Listing Service
Viking Rear doors, replacing weather striping
Discussion in 'Viking Yacht' started by jetawave, Mar 16, 2013.
  1. jetawave
    jetawave New Member
    Newtown, CT/Bridgeport, CT
    Hi, Has anyone replaced the weather striping on the rear sliding door on a 1976 35' Viking? I am not sure if they can be replaced in place or if I have to remove the doors. Also the fixed panels, Has anyone ever removed these or can the weather striping be replaced in place. If anyone has any information I would vary appreciative.
    Thanks, Gary
  2. roadking110
    roadking110 New Member
    Coxsackie, NY
    rear door fix
    I redid my my doors. I used a different top track (read that available)and put small wheels to keep the bottom of the doors at the right angle. I got rid of the bottom track. Water would collect in the track and there is a hole to let the water drain into the bildge,which caused some floor rot. I dammed the track up with A brown thyicol caulk. Then I cut out the aft facing sill, so now the water simplely sheds to the rear deck.
  3. RT46
    RT46 Senior Member
    I suggest, take out the glass sliders and upgrade to a single door and bulkhead with window.
    I bet in the end it will be about as much work and look really nice when done
