Click for Northern Lights Click for CL Yachts 99X Click for Burger Click for Nordhavn Click for Glendinning
TAMD74 EDC doesn't go beyond 2000 RPM
Discussion in 'Engines' started by Geo Bouch, Jun 23, 2016.
  1. Geo Bouch
    Geo Bouch New Member
    huntington harbour
    Hi, i have a 2002 Sealine T47, with two TAMD74 EDC. The port engine has a diagnostic code of 2:7, and it doesn't go beyond 2000RPM. Any suggestion on how to look for the solution, or what to do to figure out the problem/solution?
    thanks alot,
    Geo
  2. Jnicholas
    Jnicholas Member
    Long beach ca
    Any input on your rpm issue? I don't have my code book handy on the diagnostic code but did that fix your problem?
    I have same engine and no code errors but still have lower rpm
    Appreciate any feedback you may have
    Jerry
  3. themaster
    themaster New Member
    sydney australia
    DTC Explanation Cause Reaction Action
    System receiving no signals from
    control potentiometer.
    Engine runs at constant 1000 rpm.
    Check control potentiometer wiring and connec-
    tions and connections to control position. Erase
    DTC. Start the engine.
    If the fault persists shifting can be carried out
    directly on the reverse gear solenoids.
    2.6/ Control potentiometer
    2.7
  4. themaster
    sydney australia
    i got the same problem with my engines with no code & working on it now hope I will get on top the problem & I will send you feedback as we go
    Trader1138 likes this.
