Click for Perko Click for Ocean Alexander Click for Burger Click for YF Listing Service Click for YF Listing Service
Sunroof on my 63' Predator stuck
Discussion in 'Sunseeker Yacht' started by SHAZAM, Apr 24, 2010.
  1. SHAZAM
    SHAZAM Senior Member
    The Ghetto
    Doesn't open up and the owners manual is useless. Is there a way to manually open the top? Where in the arch is the opening mechanism located and where's the access?
    Thanks in advance.
  2. Henning
    Henning Senior Member
    Ft Lauderdale FL
    First question is, is it physically stuck or is the opening mechanism not working? I used to run a 61' Predator and the top physically stuck due to a build up of gunk and scrud in the tracks and such from sitting at a dock with a nearby tree and upwind construction site where they were doing a bunch of dirt work. Two guys lifting and pushing while another worked the switch got it open then I cleaned everything and waxed it all up really well and it functioned just fine. Not sure where the opening mechanism was located though.
  3. SHAZAM
    The Ghetto
    Henning, thanks for the reply. It moves about a 1/16th of an inch then stops. I can hear the motor working but the roof wont move. Also, is there a locking mechanism holding the **** thing closed that I don't know about?
  4. Henning
    Ft Lauderdale FL
    I never noticed a locking mechanism, not to say there isn't one. Can you physically push it past the jam point while someone holds the switch, shaking it vertically at the same time? Have you inspected the tracks best you can for something that may be causing the bind?
  5. SHAZAM
    The Ghetto
    Henning, you were right on the money. It took three of us to get it to move, we lubed the tracks and viola. Thanks.
    I manage a Neptunus with a similar top, Silicone spray works well and doesn't leave any sticky gooey residue for dirt and such to get caught on.
  7. SHAZAM
    The Ghetto
    Thanks for that Capt J, any specific brand preference?
  8. NYCAP123
    Always liked CRC-656.
  9. Capt J
    CRC silicone spray.....its in a blue-ish teal can
