Click for YF Listing Service Click for Ocean Alexander Click for Burger Click for YF Listing Service Click for Westport
Squadron 24v Light Circuit Issue
Discussion in 'Technical Discussion' started by Matt Dehn, Oct 20, 2026 at 5:26 PM.
  1. Matt Dehn
    Matt Dehn New Member
    Yesterday
    texas, usa
    Trying to help a friend- he has a Fairline squadron 55 - none of his ceiling lights work- pulled the panel and there are two large DIN connectors on the top rail- one derives power from the 24volt switch on the panel which is working fine- this then goes on to various 24V circuits that all work fine-- the second of these DIN connectors supply seems to come up thru the deck at the back of the panel- we are getting no voltage on this cable. If i jumper from the switched cable over to the second, his lights work- Is there a disconnect, a fuse, a breaker somewhere that controls this second cable-? Both supply cables appear to be pretty large- about 4gauge wire. I have looked in the engine room, the battery compartment, behind the panel, under the dash etc but have not found anything-- got to be something simple i am missing. My friewnd is a disabled
    First, has anybody consulted the prints for the boat?
    Has anybody contacted Fairline for further support?
  3. Matt Dehn
    Yesterday
    texas, usa
    have not contacted Fairline- if you have a contact number it would be appreciated-- i have looked through the wiring diagrams that came with the boat- they are quite extensive but do not address where this cable goes or is routed-- they show a 24 volt power source cable running to the batteries which i believe is the cable that has power. The 24 volt light duty circuits have a diagram but unfortunately it ends at the panel. right now i am leaning toward the possibility that this cable i am questioning runs back to the batteries on the same run that the other 24 volt cable runs, going to a circuit breaker labeled domestic which is on the forward bulkhead of the battery compartment-- to get at the back of it requires going over the top of the generator in the engine room and removing a cover with about a dozen screws that is over the connections- that is probably what i will attempt tomorrow.
