Click for Nordhavn Click for Delta Click for Westport Click for Westport Click for Abeking
Repowering a Bertram 46'
Discussion in 'Bertram Yacht' started by custint, May 13, 2009.
  1. custint
    custint New Member
    Trinidad
    Has anyone repowered a Bertram 46'? If so what engines, HP and transmissions used. I would like to achieve a cruise of min 22knots. What hp will be required.
  2. RER
    RER Senior Member
    Newport Beach CA
    Cummins QSM11 about 600HP should get that deep vee Bertram up above 22 knots. And most importantly they'll fit.
  3. geocash
    geocash New Member
    Long Beach, CA
    I know that on the West Coast there are a couple with QSM 11s. I also saw one in Texas with 660hp cat 3196s that claimed 26 knot cruise. If you are tight on the budget you can always go with a pair of 550HP 6V92. You loose a couple of thousand pounds and probably the simplest to retrofit.
    Sometimes you really need to evaluate if it is worth the cost and hassle to go a couple of knots faster. I really love my 46 and have it top notch with many upgrades. Still I cruise along at 19knots with the 8V71s.
  4. RER
    RER Senior Member
    Newport Beach CA
    I'm not sure I would go through the expense of changing out what I assume are now 8V71TI's for a pair of 6V92TA's. I would sooner overhaul the 8V71's. The 92 series won't even come close to the hours of service the 71's will give you. If I'm going to spend the money to re-power then I want a new generation 4 cycle, with higher H.P., lighter weight, less smoke and better fuel economy.
