Click for Perko Click for Cross Click for Nordhavn Click for YF Listing Service Click for Abeking
IPS Transmission Problems
Discussion in 'Electronics' started by Larry Haber, Sep 4, 2018.
  1. Larry Haber
    Larry Haber New Member
    Connecticut
    I am having problems with 2006 IPS transmissions. They keep breaking.
    OK, how are they breaking? Have you ever hit anything with them? Do you service them annually? Do you have a diver keeping the props, drives, and bottom clean every month?
  3. Liam
    Liam Senior Member
    Malta
    A usual problem on the early units is the clutch. Did you change the clutch and have you fitted the upgraded 2012/13 released versions?
    The original clutch of the IPS was not designed for the pressure the joystick system puts on the shaft.
