Click for Perko Click for Burger Click for YF Listing Service Click for Nordhavn Click for Walker
Capitol gearbox
Discussion in 'Technical Discussion' started by K prendergast, Feb 6, 2021.
  1. K prendergast
    K prendergast New Member
    Australia
    I have a capitol gearbox model 4he- 10700-7411207. It wants to slip into gear at idle. Any manuals or advice appreciated. Thanks kev.
  2. K prendergast
    Australia
    Thanks.
  3. chesapeake46
    chesapeake46 Senior Member
    You're welcome, K1W1 is my source for that link & he deserves the thanks.
  4. Capt Fred
    Capt Fred Senior Member
    Long Beach CA
    Trying the search option on this forum, someone else had a similar issue and it was discussed not that long ago. As I recall the advice given was the o-rings in the selector leaking causing the trans to go into gear uncommanded. Again, as I recall this could be worked on with out removal of the trans.
  5. Boomer
    Boomer Senior Member
    Seminole
    Correct capt fred..remove the selector on top and change out the o rings...if that doesnt fix it, I was told a bushing inside the tranny will need to be replaced which requires the tranny to be pulled...on a side note, what are your operating pressures?
  6. K prendergast
    Australia
    Great advice. Thanks.
  7. K prendergast
    Australia
    Operating pressure is180psi manual says it should be 200/210 psi.
  8. Boomer
    Seminole
    I would start with removing the selector...if your remove it carefully , you can reuse the gasket
  9. Capt Ralph
    Don't let a few PSI scare you. The important part is you have a solid PSI at the correct test point.
    Have you contacted any of the shops mentioned here or in past threads?
    I do fell you have a leaking selector valve or real bad control cable adjustments.
  10. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    While your at it, I would also put on an Oil pressure test gauge . Maddox makes an inexpensive test kit. I would put that on to get an accurate pressure reading to make sure your sender/dash gauge is good. Who knows maybe you are at 200 psi.
  11. K prendergast
    Australia
    Have just brought pressure gauge to put directly on gearbox. Will change oil and inspect oil strainer on bottom of gearbox.
  12. K prendergast
    Australia
    Thanks. Will inspect selector.
