Click for Burger Click for Ocean Alexander Click for Perko Click for YF Listing Service Click for Burger
Air conditioning replacement
Discussion in 'Post Yacht' started by Post Mayhem, Jul 8, 2018.
  1. Post Mayhem
    Post Mayhem Member
    Deltaville, VA
    Hi again everyone,
    My cruisaire’s finally gave up the ghost and I have decided to replace them with Flagship Marine self contained units. The aft unit will be in the cabinet area where the old air handler was. Has anyone insulated the storage cabinets in the salon of a 43 and if so, HOW? I need me return air to be cooled same as cabin so I will need to cool the cabinets. Thanks again for your help.
    Mayhem
    They are noisy as hell and crap. I ran a boat with them and you had to manually reset the high pressure switch on each unit if they hit high pressure. Stick with domestic.
  3. Pascal
    I don’t have any experience with their self contained but their chiller system are much better built that dometic / cruisair. No proprietary boards to fail, simple reliable design, solid stainless steel pans and good drainage.
    I just spent an hour crawling to clear a drain on a cruisair air handler and because the pan is so small, you can’t reach the drain to clear it. What a pain.
    My flagship air handlers have larger drains and a serious slope in the pan.
    I agree with the construction. But there was zero isolation between the compressor and coils and the pan. Lot of vibration transferred to the boat and noisy compressor noise.
    agree
  5. Post Mayhem
    Post Mayhem Member
    Deltaville, VA
    I have installed 2 of them. One in forward cabin and one in salon. The forward unit is cool enough on return air but the aft is pulling air from the cabinet space which gets really hot. I’ve ducted chilled air to the space but the fiberglass transfers so much heat. That is why I feel the need to insulate.
