Click for Westport Click for Northern Lights Click for Mag Bay Click for Glendinning Click for Nordhavn
671 turbo issue?
Discussion in 'Engines' started by Boomer, Jun 22, 2018.
  1. Boomer
    Boomer Senior Member
    Seminole
    Just got the boat back in the water...was cruising great then bam!! Grey smoke out of the exhaust..pulled her back and while motor was idling there was a metallic sporatic clanking going on above the tranny in the area of the turbo...good oil pressure and temp was good..shut her down and limped home...had bad smelling grey smoke backing out of the Walker air sep....how can you tell if turbo went bad? Can you tell by spinning the fins?
  2. d_meister
    d_meister Senior Member
    La Conner, WA.
    It may be obvious when you access the intake turbine with the air filter and hoses removed. The visible turbine should have no scratches or marks on it. Then, using nothing more robust than your finger, there should be no detectable side-to-side motion of the turbine, and only the slightest (if any) in-and-out play. The turbine should spin easily.
  3. Boomer
    Seminole
    Thanks...will check it...missing a lot of oil in the motor
  4. d_meister
    La Conner, WA.
    The turbine shaft floats in a layer of oil in the bearings. It might be that the exhaust side oil seal is gone, allowing oil to be pumped into the exhaust to burn, possibly explaining the gray smoke. but don't quote me on any of it, since I've never seen a turbo on a 671:). If it were going into the intake side, there should be black smoke, as Ralph suggested in the overheating thread.
  5. Boomer
    Seminole
    If it was pumping it into the intake side, you'd see blue smoke. Black smoke is generally unburnt fuel...…. grey can be unburnt fuel as well but can be other things.
  7. Capt Ralph
    I worried he dropped a valve and punched a piston.
    Combined with the overheating, I'm guessing a cracked liner.
  9. Boomer
    Seminole
    Hope everyone is wrong...lol...I am worried that it pumped out over 3 gallons of oil on a few minutes
  10. MBevins
    MBevins Senior Member
    Windsor On. Canada
    DO NOT run that engine until you get professional on site guidance. I once dumped a little more than that in about a half hour. Kissed that engine good bye.
    It's $30K by the time the smoke clears to rebuild.
  11. Boomer
    Seminole
    Clearly understood and agreed with!
  12. Boomer
    Seminole
    Congrats capt. ralph...you are today's winner...missing a valve stem on the aft piston...spring is laying on top of the head...this is going to be expensive...probably punched a hole in the piston also as you said
  13. Capt Ralph
    Those are the later 4 valve heads. You will need a proper shop to look the whole head over carefully.
    When the head comes up, you will probably find burnt valve seats and edges of the valves missing also.
  14. Capt Ralph
    For my notes, Please look at the injectors, lil 1/4" round tag on the side.
    Need numbers stamped on and color of tag.
    Also, Please post pics of inter-cooler, and blower.
    Thx
  15. MBevins
    Windsor On. Canada
    I would urge you to have a good look at the other head as well. I had the exact same problem a few years back. Dropped the valve while cruising took a week to get home on one engine. The following season the other engine started to show the same smoke. Called my mechanic back to have a look. He said everything was fine. I decided that peace of mind was worth a few bucks so I insisted he pull the head. Sure enough a valve was just starting break apart. We caught it before any damages to the cylinder. Rebuilt the head and went cruising. Best money i ever spent. Of course YMMV.
  16. Capt Ralph
    Agreed.
    At least pull the side covers off and send a bore scope up and look at the valves & seats on the other engine.
    Lack of use does cause a lil rust stain on the seats. This stain will get hot. Down hill from there.
  17. Boomer
    Seminole
    Pics sent...m15 injectors...can't get a good pic of them..sorry
  18. Capt Ralph
    They will be in your hands soon enough.
  19. Boomer
    Seminole
    Lol
  20. Boomer
    Seminole
    Will get the other head boroscoped
