Click for Nordhavn Click for Westport Click for Glendinning Click for Westport Click for YF Listing Service
Overheating 671ti
Discussion in 'Post Yacht' started by Posterboy91, May 21, 2018.
  1. Posterboy91
    Posterboy91 New Member
    Fort Lauderdale fl
    i have a starboard DD 671ti engine that overheated at cruise and went to 240 very quickly with the port remaining at 165. The heat exchangers were replaced 2 years ago so I am curious what else could be causing this issue and also since the Motor went that hot in temp what do I have to worry about now. I can say as soon as I took it to idle and out of gear it cooled off instantly. Thoughts?
    You picked up some trash or the impeller is failing (or both).
  3. porthole
    porthole Member
    Jersey Shore
    As above.
    I picked up a plastic shopping bag soon as I throttled up leaving Shark River inlet.
    Within seconds I went to overheat, shut down once outside and it cooled down fairly quick.
    Impeller was toast though.
  4. Pascal
    240 is very hot, I wouldn't be surprised if you have damage. Check the oil and coolant level carefully, as well as exhaust hoses. If you lost raw water flow long enough for coolant to get to 240, there is likely exhaust damage. Don't you have exhaust exhaust temp alarms?
    Check the impeller, strainer etc. when you start that engine check the pump cover to make sure it stays cool
  5. My Affair
    My Affair Member
    Mystic, CT
    How often do you replace your impellers? If your impeller broke up make sure to find all the pieces. Did your over temp alarms go off?
  6. ruby
    ruby Member
    Long Island
    Check your transmission coolers also, all kinds of things may be in there, I cleaned my transmission coolers every 2 years
  7. Capt Ralph
    Any update from the OP?
