Click for JetForums Click for Nordhavn Click for Mulder Click for Burger Click for YF Listing Service
1984 46 Viking 4 blade prop size?
Discussion in 'Viking Yacht' started by Waytofast79, Feb 1, 2019.
  1. Waytofast79
    Waytofast79 New Member
    Nj
    hey everyone was wondering if anybody knew the size to start with when switching to 4 blades I have a 1984 46 Viking with 550hp 6-92 Detroit’s in it
    Do you know your current size and top rpms fully loaded? A prop shop can tell you exactly what size you should need.
  3. Waytofast79
    Nj
    My boat at the moment is a bit under propped without it being full throttle I hit over 2450 so just trying to see if anyone has swapped to 4 blades to get a starting point
    Try calling Viking, they might know what size your boat came with and you can compare that to the size you have to find out what should be on there. Are there any large prop shops in your area, they may have a used set you could try to get a base point and go from there.
