Click for Lurssen
Click for Westport
Click for Dyna
Click for NorthCoast
Click for Broward
Click for Horizon
Go Back   YachtForums.Com > YACHT DESIGNERS > Yacht Designers Discussion > what programs do you use
Reply
Old 08-13-2007, 06:44 PM   #1
viking=74
Registered User
What design program do you use?
i want to know what programs you use.
like 3d programs or 2d ibecause i am designing a large yacht and want to use a good program.
and if its a 3d program what program do you use for a 2d drawing
viking=74 is offline   Reply With Quote
Old 08-13-2007, 07:06 PM   #2
AMG
YF Moderator
AMG's Avatar
We have had this up a couple of times, here is one thread:
http://www.yachtforums.com/forums/ya...-software.html
I still use Freehand (2D) even if Adobe bought it and stopped further development. (They think Illustrator should replace it, which is not possible).
I have a collegue using Rhino and Solidworks for 3D, mainly for CNC-production purposes.
__________________
Designing the future classics, today.
Lars Modin Design
Old 08-13-2007, 07:11 PM   #3
viking=74
Registered User
ok thanks do you by chance have the website for the dowloadable ones
i have tried to download that 2d one but didnt have any luck
Old 08-13-2007, 07:26 PM   #4
AMG
YF Moderator
AMG's Avatar
Here you can download trials http://www.adobe.com/downloads/
You have both Freehand and Illustrator and other Adobe programs there.
__________________
Lars Modin Design
Old 08-13-2007, 07:30 PM   #5
viking=74
Registered User
ok im downloading tose oh and do you have a link for the rhino and the other one
Old 08-13-2007, 07:50 PM   #6
Kevin
YF Moderator
Kevin's Avatar
Google is your friend Viking=74: LINK
Kevin is offline   Reply With Quote
Old 08-25-2007, 10:35 AM   #7
Eric Sponberg
Registered User
Eric Sponberg's Avatar
The defacto marine industry standard is one of the 3-D hull design packages plus AutoCad. Everyone uses AutoCad which makes the importation of others' drawings particularly easy.
For 3-D hull design, I use ProSurf from New Wave Systems, which is probably the easiest to use for manipulation and fairing of 3-D surfaces. It also has very versatile hydrostatics and stability calculations.
For rendering, most people use Rhinoceros, and it takes an additional level of skill to learn it. I can do fairly rudimentary tasks in Rhino, but all my primary surface generation is in ProSurf. Others that are available are AutoShip, Fastyacht, Multisurf, and for the Mac/Apple users, Maxsurf.
Solidworks is also a valid and acceptable program for generating 2D and 3D drawigns, but it is different than a hull 3D modeller and Rhino. It is a different philosophy based on solids, not surfaces. I was too well practiced in AutoCad to want to switch as swithing would not buy me any additional technical advantage. I also think that Solidworks is too intereconnected--too many subsidiary and interconnected files are created for my liking.
I find that ProSurf, AutoCad and Rhino suit me very well. For engineering, use hand calculations and a spreadsheet like Excel.
Eric
__________________
Eric W. Sponberg
Naval Architect
St. Augustine, FL
Eric Sponberg is offline   Reply With Quote
Old 08-25-2007, 11:12 AM   #8
KCook
Senior Member
KCook's Avatar
Just a side note: most all 2D programs, including some much less expensive than AutoCad, will export the AutoCad format.
Kelly
KCook is online now   Reply With Quote
Old 08-25-2007, 11:43 AM   #9
AMG
YF Moderator
AMG's Avatar
Rhino is soon out for Mac too; http://www.macnn.com/articles/07/06/...coming.to.mac/ and http://www.youtube.com/watch?v=nPF0HRbUOC0
I may try it, but for conceptual designs I will always use Freehand which is one hundred times faster and more flexible. 3D is for the next step in the design process...
__________________
Lars Modin Design
Old 08-25-2007, 06:37 PM   #10
viking=74
Registered User
Can you guys actualy give me links for them. Ihave been searching with no luck. I've downloaded two things but the both were not able to be installed
Old 11-15-2007, 06:47 PM   #11
coismov
Registered User
Does anyone know of any good instructional books for teaching yourself Rhino? I have a (very) basic knowledge of 3-d from Autodesk VIZ, but would really like to specifically know Rhino. Any suggestions?
coismov is offline   Reply With Quote
Old 11-16-2007, 11:58 AM   #12
K1W1
Senior Member
K1W1's Avatar
Here is an online course here to learn Rhino
http://proboate-training.pbwiki.com/...rine+Designers
__________________
Cheers,
K1W1
K1W1 is online now   Reply With Quote
Old 02-03-2008, 02:37 PM   #13
cnkale80
Registered User
Software
I would like to design a yacht of my own but I'm not sure where to find the right software. Can anyone help me out? Thanks!
cnkale80 is offline   Reply With Quote
Old 02-03-2008, 03:23 PM   #14
SINKorSWIM
Registered User
SINKorSWIM's Avatar
I would say you should use a 2d program like freehand. Then use maybe a 3d cad program like rhino or maxsurf.
(p.s.if this is somewhat messy I am sorry because I am using my iPhone.)
SINKorSWIM is offline   Reply With Quote
Old 02-03-2008, 03:25 PM   #15
AMG
YF Moderator
AMG's Avatar
Hi, there are many types of software but you need to know how to design a yacht as the software is not of much help until you are a good way into the design.
I think you will find out some more on this site;
http://www.boatdesign.net/forums/forumdisplay.php?f=4
__________________
Lars Modin Design
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All times are EST. The time now is 02:47 PM.
Click for Burger
Click for Nautical Structures
Click for Rybovich
Click for Christensen
Click for Lurssen
