Click for Westport Click for Nordhavn Click for Mulder Click for Nordhavn Click for Ocean Alexander
506 Sealand Vacuum head issue
Discussion in 'Technical Discussion' started by CSkipR, Jun 6, 2014.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Tonight it appears that the vacuum pump on my head has quit working. Its still getting fresh water okay and the seal is fine just no vacuum pump making its noise. Assume the pump is bad. Does this require replacing just the motor or the whole pump assembly?
    Is there anything else that might cause the pump to quit working. Breaker is on and will check for voltage tomorrow but assume it is okay.
  2. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Check the vacuum switch. If it is not working the pump will not come on.
    And check if there is a fuse for the pump as well.
  3. CSkipR
    CSkipR Member
    Determined problem. It was not related to the pump. Unfortunately its the battery charger and the whole 24v system is down. Will post for any advice.
  4. Pascal
    Install a blue sea digital volt meter with alarm in a place where you can easily see it... Saloon, galley, wherever you spend a lot of time. Way too often meters are buried behind solid doors where you can't see then until notice the lights are dim .. The blue seas have a buzzer alarm you can set..
  5. Old Phart
    Old Phart Senior Member
    I dunno
