Click for Quantum
Click for Moonen
Click for Lurssen
Click for Oceanco
Click For Dockwise
Click for Westport
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Plankton and Watermakers
Reply
Old 11-24-2008, 08:43 AM   #1
Pascal
Senior Member
Pascal's Avatar
curious to know how others handle plankton up north during the summer. We had a watermaker installed before heading north in the spring (900gpd sea recovery) which has been almost useless as the prefilters clog up after only a couple of hours.
The installed did include a plankton filter before the pre filters but it clogs too fast. The pre filters are the standard type, not the commercial sized models for which space would have been too tight.
The installer is in south florida and not very experienced with plankton issues, the dealer up in Newport said not much can be done.
Looking at the Sea Recovery site, i see they have a media filter, similar to a pool filter that can be backflushed. it looks like it would trap plankton and other solids, hopefully lasting longer (and back flushing is easier than replacing/cleaning 3 cartirdges)
Is this the best option?
Pascal is offline   Reply With Quote
Old 11-24-2008, 10:08 AM   #2
K1W1
Senior Member
K1W1's Avatar
A few years ago I ran a boats engine room in Alaska in the summer.
We had a flushable sand filter and also a cannister with 6 Wound Cloth Filters on each 15,000 Lt per day machine.
The Wound ones would do approx 36 hrs operation, could be back flushed and cleaned by an onboard made device and re used for about 12 hrs.
Next time I am sailing there as Chief I will make sure I have plenty of spares so I won't need to perform the rudimentary cleaning cycle.
__________________
Cheers,
K1W1
K1W1 is online now   Reply With Quote
Old 11-24-2008, 10:27 AM   #3
Marmot
Senior Member
Having spent a great deal of time in SE Alaska I will confirm K1W1's statement and advice. Backflush filters and plenty of string filters are the only solution. Don't scrimp on inlet piping size either, flow is reduced quickly enough as it is.
Marmot is online now   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 01:58 PM.
Click for Heesen
Click for Nautical Structures
Click for Dyna
Click for Heesen
Click for MCC
