Click for Westport Click for Nordhavn Click for Ocean Alexander Click for JetForums Click for Walker
winterize a 46 post with 671's
Discussion in 'Post Yacht' started by ruby, Oct 15, 2012.
  1. ruby
    ruby Member
    Long Island
    My boat has a hose coming from the seacock to the tranny cooler and then to the raw water pump, there is no in line sea strainers in the bilge. What is the easiest way to get antifreeze into the raw water side of the engines.
    Take the hose off of the thru-hull seacock, stick hose into a 5 gallon bucket with anti-freeze and run motors, or if the hose is long enough and there is enough height you could probably lift the hose above the engine height and fill it will a funnel till coolant comes out of the exhaust.
  3. ruby
    ruby Member
    Long Island
    winterizing
    That is how I used to winterize my old boat, but the hose going to the seacock is short and extremely stiff. I was wondering if anyone has added something close to the waterpump hosing to aid in winterizing.
  4. Beau
    Beau Senior Member
    Beaufort, NC
    Ruby
    I have the same problem on my 820's. I don't know your set up, but I disconnect the water outlet going into the exhaust and pump the antifreeze in in reverse. I tank out the bleed screw on the water pump and wait for that to turn pink. I also take out the drain plug in the thru hull for the intake to be sure that's drained of water from the thru hull to the pump.
  5. jhall767
    jhall767 Senior Member
    Middle River MD
    I agree there's no way to take that hose off. Mine is 2 1/2" in diameter and maybe 7" long.
    This is how I do it on my 671's;
    There should be a fitting (1/2 pipe plug) on your raw water pump. Run a hose from this to a five gallon bucket of antifreeze. Close the sea cock. When you start the engine the raw water pump will suck the antifreeze out of the bucket and through the engine. Open the seacock when on land and any remaining sea water should drain out.
    HTH
  6. Beau
    Beau Senior Member
    Beaufort, NC
    jhall
    I winter in the water, so I have to use that plug. You describe an interesting way to get the antifreeze in, though. My pick up hose has to be an easy 5 inches in diameter. I wonder if I could get enough antifreeze thru that hole for my set up? Would be much easier than the way I've been doing it.
  7. jhall767
    Middle River MD
    On the 671's (at least the ones I've checked) the plug is on the suction side of the pump. It works very well. I have 3" ball valves attached directly to my sea chests so I know what you mean about disconnecting to winterize. If I leave the boat in the water I keep enough heat in the engine room so the sea chests don't freeze. I have thermostats on my block heaters so it is not a big deal to do.
  8. Capt Ralph
    OR, bring them south.
  9. Laurence
    Laurence Senior Member
    Chattanooga TN
    Engine room heat
    While here in the upper South its not the prolonged cold most of you experience, we do get weeks in the low 20's. I also plug all vents in the engine room and run heaters.
  10. RT46
    RT46 Senior Member
    Ruby,
    I totally understand that hose can be a real PIA to get off the through hull.
    To winterize the mains;
    you can take the impeller out of the RW pump and then pump the pink stuff with a low pressure pump through one of the zinc fittings on your tranny cooler until you have pink coming out the exhaust.
    If storing on land leave the through hulls open so the standing water drains out.
    good luck
    RT46
  11. chesapeake46
    chesapeake46 Senior Member
    yet another method of winterizing a 671
    I have the same set up of ball valve to trans cooler.
    I remove the brass zinc fitting on top of the trans cooler and attach a pipe nipple, w/ a street EL and hose to the anti freeze jugs.
    Close the seacock,start the engine.
    When your done the remiander will run back down to the closed ball valve.
    I think I use 4 gallons, maybe 5, with this method, per engine.
    In addition, I have a little push button set up on alligator clips so I can start the engines right there.
    Sad time of the year.
    I hate to winterize but, I know if there were no change of seasons here, my house would prolly fall down around me cause I'd never stop boating. :eek:
  12. C team
    C team Senior Member
    Kent Island
    The 46' Post I run has crash valve's with a hose that is in the bilge under the cockpit. I close the engine raw water intake valve and put the hose in a 5 gallon bucket with antifreeze and fire up the engine. Suck up the antifreeze and shut down the engine. Very simple.
  13. coastalgeorge
    coastalgeorge New Member
    Red Bank NJ Navesink River
    C-Team,
    I like that set up. I do not have the crash pump set up, but maybe i will invest in that this off season. I am going to change almost all my Sea Cocks anyway this winter. Whats a little more piping when your already into it. My mains Sea Cocks are slightly difficult to get to, just outboard of the shafts aft of engines, if i install crash pump set up maybe i will extend the tee piping over the shafts and ball valve the Tee'd pipe closer to center of engine room. well at least thats what i think in my office as I type, maybe some restrictions once i look at this weekend. Good Luck all winterizing, UGHHHH.
    George
  14. C team
    Kent Island
    George, the sea cocks on this Post are also aft of the engines and outboard of the shafts. Yes, these are a bit hard to get to and I would not want to do this while under way if you had an emergency. I also believe these were installed from the factory. I won't winterize the engines for a little while since this boat stays in the water under a shed.
  15. tribox31
    tribox31 New Member
    north shore li ny
    winterize 671s
    if you remove the zinc off the push side of the raw waterpump you can pump antifreeze thru the whole motor, then remove the zinc off the trans cooler if it is before the raw pump and pour antifreeze in the cooler, pure antifreeze will dilute any water in there to nothing, for the most part when the boat is pulled almost all the water drains out anywhy, i have done this to my 671s for 10 years now and never had a problem
  16. ruby
    ruby Member
    Long Island
    winterize
    Well I did winterize the engines, genset, and air conditioning the other day. I was able to put a bar on the seacocks and close them. I did make a fitting to go on the transmission cooler and attached a hose to it that went into a 5 gallon bucket of antifreeze, it sucked the antifreeze out within a minute and I had added another 3 gallons just to be safe. Everything else was easy. I will finish blowing the fresh water system out and take the plug out of the engine mufflers to drain, then I am done. I want to say thanks for everyones input. Beau I see you stayed wet this winter, they got it all shrink wrapped and ready for the winter, I am next door.:)
  17. Beau
    Beau Senior Member
    Beaufort, NC
    Hey Ruby
    Yeah, she's all covered. I've stayed in the water each year of the last 13 except one. I thinink it "regularizes" (is that a word) the temp changes.
    Interesting to read all the different methods we use to winterizie an engine
  18. chesapeake46
    stiff sea cocks
    Hi Ruby,
    I replaced my seacocks with ball valves, however, my friend still has his 1979 seacocks in his boat.
    He put a Zerk fitting in place of the drain plug of the sea cock and occasionally gives them a little shot of grease.
    He tells me that they are easily moved with no real effort.
    I don't know what kind of grease he uses but I am assuming it is compatible with the rubber pieces in the seacock. maybe teflon or something.
    If you need to bar yours over to close them, you prolly should take them apart next time your out of the water and inspect them, grease them and re-install if they are not damaged.
    only 121 days til we can start them up again........:)
  19. ruby
    ruby Member
    Long Island
    winterize- JENNY
    boat parade.jpg Well this being the first winter with the Post, I do have things I want to change, ie seacocks on engines, remove 2 old thru hulls and seacocks from the original heads. I put in 2 new vacuflush's so this is the time to fiberglass them shut, and since I had the bottom stripped and redone I did want to check it and make sure everything is fine. I did make a few systems and fittings to easily get antifreeze through the boat systems, I will make them permanent so that every year they will be there, and I will bring antifreeze and a 5 gallon bucket into the engine room. I was done with everything except for the freshwater in less than an hour. Next year I will stay in for the winter. Beau I don't know if you were around last friday night but I was in the boat parade. It was much fun and an amazing crowd all around the harbor. JENNY IS IN THE MIDDLE.
  20. Beau
    Beau Senior Member
    Beaufort, NC
    Ruby
    We had a prime seat at Prime's. Jenny was queen of the fleet IMO!
