Click for Abeking Click for Walker Click for Abeking Click for Nordhavn Click for Cross
Windlass replacement
Discussion in 'Technical Discussion' started by Beau, Jul 31, 2020.
  1. Beau
    Beau Senior Member
    Beaufort, NC
    Does any one have an opinion on the Muir brand of Windlass. My 'ole Simpson Lawrence Sprint has seen it days - motor is shot among other thing on this 22 year old unit. SL is out of business as you all know.
    50', 30 ton boat would be its carrier.
    thx
  2. MBevins
    MBevins Senior Member
    Windsor On. Canada
    If everything else is good, just take the motor into an automotive starter repair facility. They'll fix you up. That's all these are
  3. Norseman
    Norseman Senior Member
    Palm Coast, Florida
    Bought a MUIR for my sailboat, took it back, the chain kept slipping on the gypsy. :(
    (Yes, it was the correct size chain)
  4. SeaLion
    SeaLion Senior Member
    I’m pretty sure SL bought Lewmar and assumed the name, so Lewmar might be helpful. I also got great advice and parts from Florida Rigging.
  5. Dan balmer
    Dan balmer Member
    Port Canaveral,fla
    Hi Beau. Went thru this on my Post 50 last season by removing the unit and disassembled the whole thing and found seized main bearing and failed needle bearing which I got at local bearing shop along with shaft seal which is what allowed salt water into the gearbox to destroy it in the first place. This unit should be removed and seal replaced every 5 yrs in my opinion and the gear box regressed and reinstalled. The motor on mine was fine. It was the gearbox that had jammed up. Anyway this was a lot of work by me with a lot of patience in the use of the right tools. My boat is a 2000 so your unit needs work. I spent only about 500$. But it was a lot of work! The new unit will also come made out of stainless. The old unit is chromed bronze that is tired looking.
  6. Beau
    Beau Senior Member
    Beaufort, NC
    Did that about 8-10 years ago. The units looking tired. By the time I get it rechromed, bearings etc changed while its open, new motor, I'm inclined to an upgraded replacement?
  7. MBevins
    Windsor On. Canada
    I head ya.
    I have an Ideal, I sent it back to them, they overhauled it, re-chromed it . It came back like a new unit. But that's Ideal.
  8. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    I had a Muir on my previous boat. If memory serves it was the Cheetah model. A horizontal unit with a rope/chain wheel. I was unable to ever get the rope to grab on the wheel without a bunch of hassle. The chain pulled in fine though. On my current boat, I installed a Maxwell 8 years ago and have been happy with it. When I first got it Maxwell had a casting issue with the wheel and the chain would slip. They replaced the wheel and it has been working great ever since.
  9. Pascal
    I m pretty sure the 70 footer I used to run had a Muir Never had a issue with it and we anchored an lot
    the boat I run now has a pair of Maxwell 4000s. My beef with them is that the chain stripper is a little weak and bends easily. It s bolted to the hawse pipe... in theory it s an easy fix but when the stripper bands it jams on the chain and the hawse pipe gets damaged. Problem is that Maxwell believed bolts are ugly so to replace the $500 hawsepipe you have to pull the whole windlass as the bolts are hidden underneath. Not a fun job. First time it happened I had holes drilled into the deck and we used longer bolts so that the hawsepipe can be removed without pulling the windlass
    still... at $500 a piece I have given up on the stripper and found that with marine grease on the Gypsy the chain rarely get stuck.
  10. Beau
    Beau Senior Member
    Beaufort, NC
    Thanks folks for your input.
  11. Wow57pro
    Wow57pro New Member
    New Jersey
    I would be interested in the gearbox if you decide to junk it.
  12. leeky
    leeky Senior Member
    Florida
    This could be good, folks. Two lawyers possibly agreeing to something. You guys have to let us watch.:D
  13. Beau
    Beau Senior Member
    Beaufort, NC
    WOW, I'm going to be replacing the unit down in NC this winter season. Top to bottom. The entire unit is available to you. Leeky probably doesn't realize it's the clients who drive the whole process - and have come to the table/court with TV series expectations. Unencumbered, lawyers more often than not can get to the bottom line very quickly.
  14. Wow57pro
    Wow57pro New Member
    New Jersey
    I appreciate your offer! Please keep me in mind when you remove it.
  15. Beau
    Beau Senior Member
    Beaufort, NC
    Will do send a PM to me and I will save it with your contact info.
  16. leeky
    leeky Senior Member
    Florida
    Guilty, as charged!:oops:
  17. Beau
    Beau Senior Member
    Beaufort, NC
    You are hereby granted a Beau-pardon. Absolutely worthless except on this thread
