Click for JetForums Click for YF Listing Service Click for Burger Click for Walker Click for Abeking
Water heater for 1980 42 post
Discussion in 'Post Yacht' started by Rover1, Jul 29, 2015.
  1. Rover1
    Rover1 Member
    Shark River NJ
    Hello All I am a new post 42 owner. Just picked up mine from Saga Harbor NY at the end of the weekend. Put her in the water turned the key and she took me home at a solid 22 knots the whole 140 miles back home to NJ. After getting her back home and getting all the systems back on line again. I noticed that the water heater has been by past. during the Survey we turned the water heater on to see if it drew any amps. Which it did so we never looked anymore into it. Once I got it home and turned the dock side water on I noticed that its been by past. My question is if it needs to be replaced, What size does anyone think I needs to be replaced with? also does it have to be a marine water heater that goes back into it or can it be one from another suppler? please anyone with any incite please let me know as I rather stay on the boat in a hot day then run across the parking lot to shower in the marina.
  2. deanpe
    deanpe New Member
    Hollywood, MD
    I replaced the heater in my 1982 42' with a 20 gal raritan 115v water heater.
    It was a similar size to the one that was in the boat when I purchased it 5 years ago. The one in the boat was rusted out and was leaking. It seemed to be a similar tank to what you would see in a mobile home or small apartment. It wasn't necessarily "marine grade". I don't know if it was original to the boat or not.
    In retrospect, a 20 gal was probably overkill but I got a good deal on a scratch and dent model. A 12 gallon model is probably adequate.
    You may want to check the functionality of yourheater before going through the trouble and expense of replacing it. The previous owner had a bypass hose for the hot water tank that was used when winterizing the boat. It allowed you to drain the tank but still flush the fresh water system with pink antifreeze; saving the expense of running 20+gal of pink stuff through the hot water pipes.
  3. Rover1
    Rover1 Member
    Shark River NJ
    Thanks for the point in the right direction. Looking at them now. Now I just have to drive back to the boat and see whats in there now and if it fits, Cant see a 82 being that much diffrant then a 80.
  4. Davidoc
    Davidoc Senior Member
    Winter:Delray Beach, Fl Summer: Bahamas
    That was a good point made by Rover 1 about the bypass reason. You said your heater drew current on the survey so chances are if you reconnect your heater to your system she may be all good.
    If you do replace the heater, I would recommend using a marine grade heater that has a stainless steel inner liner. Make sure you can change the actual heater element without tearing the whole boat apart to get to it.
    Another option is to replace the heater with a small instant on unit about the size of a brief case and reclaim all the space that the existing heater uses. You already have to have shore/genset power to heat the water and you never know when its going to kick on. The only disadvantage is you don't have the holding tank to store warm water.
  5. mwwhit1
    mwwhit1 Senior Member
    a
    Agree on the bypass being used for winterization. I do the same thing. So it may still work OK. I replaced mine 2 years ago with an 11 gallon Seaward. Haven't run out of hot water unless we take 3 showers right after each other. If you have to replace, make sure you measure how much room you have between the engine and generator. I had to take the Seaward apart. The inner tank just fit through then put the outer skin back on. Not a big deal. If any bigger, I would have had to remove engine cooling pipes, drain engine coolant, etc. Your engines may be slightly different config than my 84's.
  6. deanpe
    deanpe New Member
    Hollywood, MD
    Good point about get the the old heater out and the new heater in. For my 20 gal raritan, I had to temporarily remove the 4x4 wood support that holds the salon floor to give myself enough room too remove and replace the heater. I used a bottle jack to support the floor a little forward of the original support. I unscrewed the support but also needed to used a sawzall to cut through the adhesive used to bond the wood to the stringer. I used some liquid nail framing caulk when reinserting the support then reused the screws. Looks like factory!!
  7. Rover1
    Rover1 Member
    Shark River NJ
    All of these suggestions are a big help. this weekend i'm going to try and hook the pipes that were by pasted back together, Just to be on the safe side and know for sure that it is dead. I thought the fridge was dead also cause it wasn't getting cold but then someone noticed that the fan just wasn't turning. Now the fridge works fine. So maybe with any luck they did just by pass it because they were winterizing it. Well see. ill let you all know.
  8. Rover1
    Rover1 Member
    Shark River NJ
    Well unhooked the by pass for my water heater fired her back up. To my suprise hot water! Only after I went back down to check on it for a second time. There was water leaking out of it, so the idea that they by passed it for winterizing went out the window at that point. So now it's back to the search for a new water heater.
  9. Rover1
    Rover1 Member
    Shark River NJ
    Replace the water heater with a new unit. Getting the old water heater out was NOT a simple task. Had to take apart the support for the deck above the gen set and almost had to take the Gen set out all so. But with a lot of patience and multiple beers to the helpers on the dock shes got hot water again!
  10. Davidoc
    That's great. What type of unit did you put back in?
  11. Enterprise
    Enterprise New Member
    Delaware
    I'm new to the forum and I have a 1982 42' Post. I put in a 6 gallon water heater, I believe a Force. It's in a stainless steel box. I've found 6 gallons to be plenty because I've always turned the water off while soaping. With quick recovery, I've never run out, even when people take showers one after the other.
