Click for Ocean Alexander Click for Burger Click for Burger Click for Abeking Click for Walker
Voltage/Air Conditioner Question
Discussion in 'Sea Ray Yacht' started by klaffey, Jul 30, 2008.
  1. klaffey
    klaffey New Member
    Lake of the Ozarks
    I am getting a high voltage reading on my starboard engine. I have a '99 Sea Ray 400 Dancer with Mercruiser 380's in it. Any one have feedback on what might be causing this?
    May airconditoner's also appear to have thermostat problems as they read te inside termperature as 10-15 degrees lower than it really is? Any ideas?
    Thanks!
  2. Pascal
    re voltage, start by measuring the actual voltage at the battery terminal with the engine running over 1200rpm and see the gauge is accurate.
    you didn't say how if the voltage, but if your'e also getting high voltage at the battery (over 15V on a 12v system), then teh alternator/regulator is suspect. Pull it and take it to a good alternator shop. Make sure they deal with marine stuff, you dont' want non ingition protected componenents on a gaser.
    AC... make sure the outlet arent' blowing cold air directly on the Tstat...
  3. wingless
    wingless Member
    East Coast
    The alternator on my 2000 7.4 Mercruiser Horizon 380hp has an integrated voltage regulator that went bad and wasn't available as a separate component.
    The entire alternator / regulator needed to be replaced to correct the over-voltage problem.
  4. Henning
    Henning Senior Member
    Ft Lauderdale FL
    Who said it wasn't available as a separate component? Did you take it to an auto electric shop or the dealership? I ask because I've never seen one of the GM/Delco, or any other alternator where you couldn't buy every component, including the regulator, individually and overhaul it.
  5. wingless
    wingless Member
    East Coast
    Oh.
    When the regulators in my "862031T 65A Delco Non-servicable, replace complete assembly alternator assembly" failed, I contacted Delco, Mercruiser, many web sites and several local repair shops and got the same story, replace the whole assembly.
    At some point these will fail again, so what is the regulator part number, who can I purchase this from or who can repair this non-servicable alternator?
  6. wingless
    wingless Member
    East Coast
  7. Marmot
    I am over-regulated but have no regulator parts.
    Google is your friend, you can save yourself much money.
    Hint: look for manufacturer's part numbers. Mercruiser doesn't build engines or accessories.
    I will take Henning's side on this issue, if a component is made of several parts, there are parts made for it and someone sells them.
    OK, it's Christmas: :)
    Top of page 15:
    http://www.wagneralt.com/catalog/books/CAT%2008%20regulators%202007.pdf
  8. wingless
    wingless Member
    East Coast
    Thanks for the info. google is a good place to look? Great advice.
    When I searched and I called all I found was that the failed regulator was not available separately and that the alternator could only be replaced as a complete assembly.
    So the D08-73 is the voltage regulator for the 862031T?
    Thank you.
  9. Marmot
    If I were buying it I would confirm that with the supplier or manufacturer. I wouldn't take my word for it ... :D
  10. wingless
    wingless Member
    East Coast
    This is the voltage regulator installed on my 862031T alternator.
    The D08-73 on page 15 looks like a visual match.
    Good find!
