Click for Walker Click for Delta Click for Cross Click for Westport Click for Burger
UV Dye for chilled water system
Discussion in 'HVAC' started by corinthian99, Sep 17, 2010.
  1. corinthian99
    corinthian99 New Member
    London, UK
    Hi, can anyone recomend a good UV visible dye for tracing leaks on our chilled water system. Have seen it used previously and even had some onboard ages ago but can't remember the brand. Thanks guys.
  2. K1W1
    Have a look here, it is my understanding that IR Fliud can be added to any system that can handle the actual chemical it self.
    http://www.hydratech.co.uk/coolflowproducts.html
    If your Chilled Water is leaking surely you are getting a pool of it somewhere even if it is just running out of the Aermaflex somewhere metres from the leak
  3. corinthian99
    London, UK
    Thanks for that I'll get in contact. Bit of a mystery leak been with us for years apparently but nowhere obvious, and god knows we've looked. Thats why we're resorting to the UV dye, **** stuff must be leaking somewhere.
  4. NYCAP123
    Condensation maybe??? The dye will answer that if it doesn't show up.
  5. K1W1
    Knowing that this guy works on the bigger boats I would say it is a drop in system pressure that makes him aware that the water is going somewhere.
    The larger CW Systems usually have a coloured Anti Freeze in them which makes leaks obvious, I guess he wants the UV Trace because he is looking in some hard to access spaces, something that there are lots of on a 60 -80m yacht.
  6. NYCAP123
    Good call. They all have those impossible spaces, even the small girls, but I hadn't considered the preassure drop which the boats I run don't monitor.
  7. wdrzal
    wdrzal Senior Member
    Tracerline makes UV dye for refrigerants,oils and water based coolant systems. I use them pretty often with good results. Get a good high powered (150 watt)UV light, some of the small one using LEDs are junk. I seen some good prices on complete kits,uv dye,light, uv cleaner,uv glasses on Ebay for cheap.
    I have a # tp-1620 kit here
    http://www.tracerline.com/kits.html
    additional dyes:
    http://www.tracerline.com/dyesforfluids.html
    If that doesn't work ,You can empty the coolant system and fill the coolant system with Helium and use a helium detector. Helium has a very very small molecule and will find the tinyest leak. And it's rare in the atmosphere,so no false alarms. The ony draw back is helium detectors are expensive.
    Good luck
    I have never worked on a yacht with a chilled water system that did not loose coolant water. A real bear to trace.
  9. corinthian99
    London, UK
    Thanks for that Wdrzal. Hasn't got annoying enough to be draining down the system, not that I'm likely to get the down time to even consider it. I've found a couple of leaks but not the mother lode, just beginning to drive me a little bit nuts not finding it. Oh well.
