Click for Perko Click for Nordhavn Click for Abeking Click for Cross Click for Ocean Alexander
Turbo rebuild
Discussion in 'Viking Yacht' started by Waytofast79, Nov 26, 2019.
  1. Waytofast79
    Waytofast79 New Member
    Nj
    hey everyone just pulled the boat today and it’s time to get my turbos rebuilt on my 6/92s was wondering if any one had suggestions or any thoughts on this turbo blueprinting and if it is worth it please let me know
    Why is it time to rebuild your turbos?
  3. Waytofast79
    Nj
    They are sticking and is starting to have a decent amount of shaft play
    What performance do you think you have lost? What color is your exhaust?
    Please review Detroit turbo service specs.
    I can not cipher sticking but understand shaft play. Air Research, Garret and others have a good bit of for-rear play when spinning at finger pushing rpm.
    When running the oil offers good flotation on the shaft that is never realized (by finger feel) and center float is realized.
    I'm not trying to be a smart asp, but good spinning turbos should not be screwed with until a real symptom is or about to come on.
    Let me say it this way, Zero problems with running take off turbos to fix my customer real issues. Lots of problems with rebuilt turbos. I luv used parts.
    Can you take a hint??
  5. Capt Ralph
    In case you are not familiar with my maintenance schedules here on Y F, It's simple;
    Never kick a sleeping dawg...
  6. Waytofast79
    Nj
    The turbo stuck bad over summer to where a 7/16 socket was needed to break free and for last two seasons when spinning the turbo by hand it’s not smooth and also the shaft play is not only in and out slightly it’s up and down and can see where it made slight contact with the housing
  7. Capt Ralph
    Then you may have one bad turbo.
    Don't purchase a whole unit, DDC offers just the middle cartridge (your failed part).
    Serial number in hand, go to a real DDC shop and get just the mid cartridge.
  8. Waytofast79
    Nj
    yea I already tried to do that but is on back ordered at Johnson and towers so I’ll get them rebuilt
  9. Capt Ralph
    Junk & Trash?? Try a real DDC shop yet?
    IMO, only mess with what has failed.
  10. Capt J
    If it's contacting the housing, the bearing is shot and you should address this ASAP before it sends pieces of the turbine through your engine. Not sure on the blueprinting of turbo's but couldn't hurt.
  11. MBevins
    MBevins Senior Member
    Windsor On. Canada
    If you're going to send them in.
    Superior Turbo & injection in Detroit are real DDC rebuilders.
    Without the "Marine" mark-up
  12. boatpoor
    boatpoor Senior Member
    I pulled one and disassembled it back in October for basically the same reason. The bearings were still good and the compressor was good but the turbine housing was corroded internally to the point that the turbine couldn't spin. There were no housings available anywhere that I could find at the time but Detroit offers a complete reman for around $3,200. I deal with Williams in Birmingham,Alabama. They still had 4 on the shelf, but as soon as I get a break at my real job I'm going to replace my other one, so they'll have one less. Looks like the salt air through the exhaust took its toll on the cast iron.
  13. boatpoor
    By the way, if it's the TW 8301 turbo, it will have bronze bushings and you can replace them for about $150.00 if that's the problem and the shaft and housing aren't damaged.
  14. CaptPKilbride
    CaptPKilbride Senior Member
    On the water
  15. C team
    C team Senior Member
    Kent Island
    I like that Capt Ralph! I'll have to remember that name!
  16. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Had 2 turbos 'rebuilt' by a well know company. The single most shyte shower of a job I've ever seen. Dreadful.
    Just buy new aftermarket ones, like for like and cheaper.
  17. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    I got mine from J & T two years ago An Un-Reliabuilt product ...but it's been good so far. Mine are small for 471. Air research units.
    Not sure if YF peeps know this but J & T and Western Branch are under the same ownership. Not sure who bought who. OR if it's some sort of alliance.
  18. Capt Ralph
    WB also took over the Convington line of marinized Detroits.
  19. Capt J
    Covington was Western Branch I believe. Or vice versa. Covington became Western Branch.
  20. Waytofast79
    Nj
    Ok awesome thanks everyone going to pull both turbos this weekend boats on land for the season so can take my time
