Click for Burger Click for Westport Click for Cross Click for JetForums Click for Delta
Trans-Atlantic Delivery Tips?
Discussion in 'General Yachting Discussion' started by ayachtguy, Jan 16, 2012.
  1. ayachtguy
    ayachtguy Senior Member
    Florida
    Planning a spring trans-atlantic crossing on a large yacht (120'). Looking for tips from you experienced skippers for things I might overlook. Got the basics down...cover the carpets, shrink-wrap the soft goods, strip off the canvas, etc.
    Other tips? Thanks!!
  2. K1W1
    You might also want to check all things mechanical before yu go and after you arrive if it s A 60HZ boat carry a few essential spares such as any motors needed to run Steering, AC etc as 60Hz stuff n Europe is hard to find if available at all locally.
    Light bulbs can also be another difficult acquisition
    Once you get there are you going to plug into shore power?
  3. ayachtguy
    Florida
    Good point on 60hz spares, but I'm really looking for tips on ways to protect the boat and gear enroute. I'm interested in wx routing experiences, too. We're ok for shorepower with an Atlas system.
  4. K1W1
    If you have deadlghts for hull windows etc that would be good, if not have some ply in case you loose a window and need to make a repair.
    Filling up the chain locker is another one to look at preventing , plenty of fuel filters, make sure your EPIRB info is up to date. Do you have any risk of sea water getting into tank vent pipes etc?
    I am currently in the Bay of Biscay on a vessel a lot larger than what you are going to be crossing on - even when it is "calm" the sea conditions can make you glad you are well prepared.
    I have had some great crossings in springtime from Carib to Med heading straight to Gib from Antigua and also by heading North towards Bermuda and then over to Gib.
    If you do not have big fuel range you could go from the East Coast to Bermuda and then hop over to Azores then Gib then on into Med if that s where you are aiming for
  5. ayachtguy
    Florida
    Kiwi--
    Good point on ply for repairs!!
    Something missing in your sentence on filling the chain locker to prevent ????. Water, I assume. Fill with??
    Also good point on the tank vents. Will give some thought to that.
    Thanx!
  6. K1W1
    Yes it is to prevent water getting in.
    The Spurling Pipes can have rags stuffed down beside the chain and sealed with expanding foam or a cement and sand mix - whatever you use make sure it can pull out easily if you want to drop anchor in a hurry.
    Also any electrical boxes,switches for anchor windlass, lights etc on the foredeck should be very well waterproofed and isolated electrically at source if they are likely to get wet.
    What sort of boat is it your crossing on?
  7. ayachtguy
    Florida
    I'm good on the spurlings, which have a tight removable cap that we secure at sea, but very good point to scout around for any electricals. This is a converted Peterhead Scottish fishing trawler...slow but steady, about a billion mile range at cruise, and tends to throw water everywhere. What are you on in Biscay?
  8. revdcs
    revdcs Senior Member
    Fowey in Cornwall
    You might also want to check with your insurance.
    If you haven't made crossings before as Captain, then most insurance companies require a Captain who has made several crossings to at least be on board, if not in command.
