Click for Walker Click for Cross Click for Abeking Click for JetForums Click for Westport
Sliding Cabin Door
Discussion in 'Post Yacht' started by ReeLeeHooked, May 29, 2016.
  1. ReeLeeHooked
    ReeLeeHooked New Member
    Taunton, MA
    I have a 1987 43' Post. All of a sudden it getting a lot harder to slide the door open and close. Just wondering if there is some type of adjustment or the track should be greased? If the latter what type of grease?
  2. RT46
    RT46 Senior Member
    check the screws in the center of the upper door track/slide.
    If those loosen it will cause the door to stick and be hard to slide.
  3. ReeLeeHooked
    Taunton, MA
    thank you, will do.
  4. P46-Curaçao
    P46-Curaçao Senior Member
    Also, the rollers in the upper track rail can be adjusted, it look similar as shown below.
