Click for Westport Click for Burger Click for Nordhavn Click for Westport Click for Glendinning
Simrad AP pump brushes
Discussion in 'Electronics' started by Pascal, Sep 20, 2019.
  1. Pascal
    second time in three years I had an AP pump failure “Rudder movement failure”
    Took me a while to figure it out the first time around... turned out to be dirty motor brushes.
    Is that common with these pumps?
  2. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Mine hasn't been serviced in the 20 years I've owned it and I highly doubt the previous owner touched it.
    I use it every time I use the boat. Is this on your personal boat?
  3. Pascal
    No, on the Lazzara 84 I run. 10 years old... mains have 3000 hours half of that in the last 3 years, most wiTh AP on
  4. MBevins
    Windsor On. Canada
    Do you have the resources to check the operating pressure?
    I'm wondering if the load is high this causing excess current draw through the brushes.
  5. Pascal
    No i don’t but the helm feels right...
  6. wdrzal
    wdrzal Senior Member
    Check to see if there is wear on the commutator, usually it becomes concave. On some, depending on wear you can remove the armature and take a few thousands off the commutator on a lathe. Fitting new brushes, I always get a sanding drum that matches the radius and sand in the curve. Putting flat brushes in causes a lot of electrical arching that can damage the commutator, insulation on the windings or the brush itself.
  7. MBevins
    Windsor On. Canada
    Yes, what he said.
