Click for Abeking Click for JetForums Click for Cross Click for Ocean Alexander Click for Delta
Sealand in line odor filter
Discussion in 'Post Yacht' started by ESSRTEE8, Feb 14, 2015.
  1. ESSRTEE8
    ESSRTEE8 Member
    56 POST in Monmouth Beach NJ
    I am wondering if your late model Posts have a Sealand odor filter installed.
    I cannot find one on my 56 and was wondering if the 50's or any other late model Posts had them installed from the factory.
    If you have vacuflush heads, they should have one. Follow the vent line from the tank to wherever it goes.
  3. ruby
    ruby Member
    Long Island
    Check in the cockpit , under fish box
  4. ESSRTEE8
    ESSRTEE8 Member
    I did that. My holding tank is in the bow so I would suspect the vent is up there too.
    There is a panel in the back of a closet in the forward stateroom that I might be able to remove, maybe it's behind that.
  5. Beau
    Beau Senior Member
    Beaufort, NC
    My 1998 50 does not, that I know of - but maybe I will learn something from another 50 owner??
    Just follow the vent line from the tank to where it exits the hull. If your tank is in the bow, the filter and vent should be close to it. If you have vaccuflush toilets, you need a sealand filter. I removed it on a 58' Azimut that only had a full idiot light that the owners didn't pay attention to, MAN when you flushed a head, you'd have to run for about 75 yards because the smell on the dock was unreal.
  7. ruby
    ruby Member
    Long Island
    The filter on a vacu flush system is USUALLY close to the holding tank
  8. NYCAP123
    Actually, I was surprised to learn some time ago that not all Vacu-Flush heads have filters:
    RB480Senior Member
    "Generally most carvers did not have the filters. 20 years on mine without filters. No smell, nothing."
  9. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Mine is under the master bed. It lifts up for storage and under that is an access panel to change the filter.
  10. ESSRTEE8
    ESSRTEE8 Member
    What model CSkipR?
  11. ESSRTEE8
    ESSRTEE8 Member
    Per Sealand/Dometic rules, they are all to have the in-line filter. Not sure if the Post factory followed the guidelines or not.
    I hope they did.
  12. CSkipR
    CSkipR Member
    Sealand with 3/4" fittings. Boat is Cabo although I think most vacuflush use the same filter. Good luck.
