Click for Glendinning Click for Westport Click for Cross Click for JetForums Click for Perko
Santego380 swim platform
Discussion in 'Carver Yacht' started by Pelican, Jun 18, 2012.
  1. Pelican
    Pelican New Member
    Lake Pepin on the Mississippi
    Hello, I am new to forums. Was wondering if anybody can tell me if there is a trick to accessing the inside of the swim platform on my 1994 38 Santego. I would like to add a transom shower. Where can I find a used factory shower hatch. Also am wondering about a larger compartment for a transfer pump hose for fueling the dinghy. Thanks for any help.
  2. Fireman431
    Fireman431 Senior Member
    East central Florida
    Adding a transom shower is pretty straight forward. Access to the water lines is in the aft portion of the bilge. Usually, there are 15mm plastic lines, easily cut and tapped into with a 'T'. The shower box can be purchased on line from just about any marine supplier (check Defender and Overtons). Cut an area out for the box, plumb the lines, seal in place with 5200.
  3. NYCAP123
    Given the size dinghy you'd have with that boat I wouldn't mess setting up a gas pump. Between the cost and the dangers I'd be more inclined to stick with 3 gal. cans.
  4. Pelican
    Pelican New Member
    Santego 380
    In addition to construction detail of the bolt-on swim platform, does anyone have any details/blueprints of the stringer and bulkhead layout for a 1994 santego 380. Trying to figure out why water will collect in the center salon hatch and not travel to the engine room bilge aft. Thanks.
  5. Fireman431
    Because that's the lowest point of the boat when settled in the water. The aft is actually a bit more shallow than midship is.
