Click for YF Listing Service Click for Cross Click for Walker Click for JetForums Click for Westport
Sabre 48 SE electric window
Discussion in 'Electronics' started by JOSEPH Fick, Oct 9, 2020.
  1. JOSEPH Fick
    JOSEPH Fick New Member
    Current Map View
    Anybody having problems with the electric power window on the Sabre 48SE?
  3. sgawiser
    sgawiser New Member
    Jupiter, FL
    There was an issue with the control on the Sabre 45 and they made a change to fix it. This was a problem where it could lower by itself.
    What problem are you having and what year is the boat?
  4. JOSEPH Fick
    Current Map View
    2016 Sabre 48 SE window just stopped working
  5. Bill Wendt
    Bill Wendt New Member
    Harbor Springs, Michigan
    I have 45SE Hull 5. Occasionally the fuse blows. I replace and it works if I push DOWN first and then UP. Now after replacing a blown fuse, the lighted green UP/DOWN buttons don’t even work.
    Any thoughts of how to fix?
  6. Bill Wendt
    The aft powered window on our 2018 Sabre 45SE stopped working. This has happened in the past and been fixed by replacing a fuse, pushing the Down button first which seems to reset the system.
    is the 48 window same as the 45?
