Click for Northern Lights Click for Glendinning Click for Abeking Click for JetForums Click for YF Listing Service
Repowering a 97 Viking sc48 with Cat 7.1 500hp
Discussion in 'Viking Yacht' started by mdwally30, Mar 30, 2020.
  1. mdwally30
    mdwally30 New Member
    san diego
    I'm looking for some feedback. Repowering a 97 Viking sc48 with new Cat 7.1's. Any thoughts or suggestions.
  2. mdwally30
    san diego
  3. PacBlue
    PacBlue Senior Member
    Dana Point, Ca
    What power are you replacing and what are your goals with the repower?
  4. RER
    RER Senior Member
    Newport Beach CA
    Probably replacing CAT 3208 435hp.
  5. mdwally30
    san diego
    I’m replacing 3208 425hp. Had one engine go bad. Other needed new heat exchanger housing and transcooler. Plan on keeping the boat for a minimum of 5-10 years. Plan is to install C7.1 500hp. Change shafts from existing 1 3/4 to 2”. Remodel the engine room basically. Looking for some feedback on the engines and any suggestions on other things I may need to be concerned about or address while I’ve got the boat out of the water. Thanks for your response and input.
  6. PacBlue
    Dana Point, Ca
    Looks like a good choice, which yard is doing the repower?
  7. mdwally30
    san diego
    Dependable Marine at Driscoll in SD
  8. mdwally30
    san diego
    I’m planning on redoing the soundproofing in the engine room. Any suggestions?
  9. PacBlue
    Dana Point, Ca
