Click for CL Yachts 99X Click for Cross Click for Burger Click for Ocean Alexander Click for Walker
Replacing the gray line plumbing with pex on my 1988 Symbol 44 Sundeck
Discussion in 'Technical Discussion' started by Steve Gotham, Aug 31, 2020.
  1. Steve Gotham
    Steve Gotham New Member
    Fort Myers Yacht Basin
    Sprung a leak in my water pipe .upon inspection will need to replace the entire system with pex. Any suggestions , tips and where might I obtain a blue print .
    Not understanding the reason to replace all with Oex. Most Pex SharkByte fittings will fix both poly and pex.
    For the perfectionist, there is an adapter to make up that 1/4-1/2 mm difference.
  3. Steve Gotham
    This is the third time my gray pipe has caused a leak. Rather just take out all the old gray pipes and replace with better . How might I go about purchasing a manual for the boat? Would like to see a diagram as to how the existing pipes are laid out.
  4. Steve Gotham
    Thanks for getting back to me.
  5. Capt Ralph
    Where has the leaks happened? At the connects I bet.
    I am not a good reference on Symbols. We do have a Member. She may pop in shortly. Maybe some factory support could be at hand.
    Judy responded to your other thread.
    Sorry to report there are no more dealers in the states any more.
    Hatteras used a lot of the polly tubing. This where I learned about all the bad connects and how to fix them.
    There is no such thing as a diagrahm for your plumbing on a Symbol. You can still buy the grey stuff at places like Home Depot and all the fittings. It's either that or buy a bunch of pex and all of the fittings, but marine and home pex are different sometimes and have to stick to one brand for best results.
