Click for Nordhavn Click for Abeking Click for Northern Lights Click for YF Listing Service Click for Burger
Ranco Electronic Temp Control in boat
Discussion in 'Cabo Yacht' started by CSkipR, Nov 11, 2012.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Today I was in the lazarette and noticed the above item mounted on the inside of the transom. No idea what its purpose is or why it would be located there. Can someone explain or help me understand what it would be doing in this area?
    It's the module for your cockpit freezer or fishbox freezer plate and is what you use to adjust the temperature in the unit.
  3. CSkipR
    CSkipR Member
    Learn something everyday. I do have a cockpit freezer and also an Eskimo icemaker in the fishbox. Would you say it probably controls the the cockpit freezer?
    Yes, as I don't believe the eskimo ice makers have a temperature adjustment. Usually Cabo mounted it on them on the rear engine room bulkhead. It has a small digital display and an up and down arrow/button?
  5. Ozzie
    Ozzie Member
    Cul-de-Sac
    I have seen where the temp sensor is mounted in the fishbox so as to control the amount of ice in the box. As long as the bulb was covered in ice the Eskimo unit would not run.
    Your post seems to indicate a photo that is not there... but the controller should be closest to what it is managing.
  6. CSkipR
    CSkipR Member
    Thats it. Thanks
    If you decide to turn up the temperature to use the unit as a refrigerator instead of a freezer, put something with holes in it in the bottom of the freezer box.....like those rubber mats for boat decks that lock together from west marine, because whatever is touching the bottom will still freeze.
    Yes on the eskimo ice maker, the little sensor in the fishbox just detects ice on it and shuts the unit off.......
  8. Bill106
    Bill106 Senior Member
    Beaufort NC
    The newer Eskimo's don't use a Ranco but the older ones did. They used a thermocouple to measure temp and when ice reached it and chilled it would shut the auger off. Newer ones use an optical sensor to detect ice level and wired it to the Eskimo's control board.
