Click for JetForums Click for Glendinning Click for YF Listing Service Click for Burger Click for YF Listing Service
PVC pipe in bilge 42'
Discussion in 'Post Yacht' started by jcovey, Jan 15, 2013.
  1. jcovey
    jcovey New Member
    great lakes
    I recently bought a 1982 42' Post and in the bilge when walk down the steps into the galley there's a white PVC pipe with a stopper in the end. Does anyone know what this is for?
  2. RT46
    RT46 Senior Member
    can you send a pic?
    Post used white 4 in PVC pipe as runners for electrical wires and plumbing.
    also, PVC is used for the stern for emergency bilge pick up plumbed to the engine intake.
  3. SeaEric
    SeaEric YF Historian
    out on the dock
    Storage tube for a spare shaft perhaps?
  4. Beau
    Beau Senior Member
    Beaufort, NC
    If its running along near the keel butt, It's a fore and aft connection for drainage. Should have something like a runabout's drain plug in it that you can remove. May want to snake it if you haven't used it for a while.
  5. RT46
    RT46 Senior Member
    Beau is right, it could be a bilge drain for under your fuel tank or ER so fuel or oil doesn't mix with bilge water.
    a pic would really help
  6. chesapeake46
    chesapeake46 Senior Member
    RT, that's what it is in mine.
    Before you pull the plug, you should get a diaper or 2 ready just in case there has been an oil spill or leakage from the cartridge filters.
    Next you should replace the cartridge filters with spin on's !
    Congrats on the new boat.
  7. mwwhit1
    mwwhit1 Senior Member
    a
    It is the drain for the compartments under the fuel tanks. Bilge water actually runs through a separate pipe under each tank so it doesn't get contaminated by a leak or spill. Should pull the stopper once or twice a year and drain out any water\oil\fuel that may have gotten under the tanks.
    Best to do it while in the water because it will have the natural downward slope to drain it.
  8. Beau
    Beau Senior Member
    Beaufort, NC
    I keep mine open so the compartment drains.... Don't want anything sitting in water all season.
