Click for Glendinning Click for Northern Lights Click for Cross Click for Abeking Click for Ocean Alexander
Primary Fuel Filters
Discussion in 'Ocean Yacht' started by Boomer, May 18, 2018.
  1. Boomer
    Boomer Senior Member
    Seminole
    How often do you change the primary Racor fuel filters?
  2. Pascal
    I usually change them at every oil change (200hrs) along with the secondaries.
  3. Boomer
    Seminole
    Thx
    Well, er, ah, oh,,,
    Dual Racors usually run one at a time. If you have a dual system, you can push them further if your equipped with a tell-tale low pressure gauge.
    AND if you have low pressure gauges after your secondary fuel filters, can help them last longer instead of guessing hours.
    Just the history of what you have been finding in the mud (Racor) filters can help the future filter service.
    So, what has your mud filters been looking like before?
  5. Caltexflanc
    Caltexflanc Senior Member
    North Carolina
    I changed mine when the vacuum gauge got near to the red line.
  6. Pascal
    With dual racor i use one at a time. At oil change i replace the one that was used and switch to the other one.
  7. Boomer
    Seminole
    New to us boat...needed a starting point
  8. Caltexflanc
    North Carolina
    It's not a pressure gauge it is a vacuum gauge.
  9. Capt Ralph
    low pressure = vacuum
    Vacuum is a state of pressure below atmospheric.
    However, for those in Rio Linda, I'll try to use the word Vacuum in the future.
  10. Caltexflanc
    North Carolina
    You don't measure vacuum with a pressure gauge or vice versa.... on your primaries you are measuring vacuum (negative relative "pressure" vs atmo) or "suck" on your secondaries before the lift pump; the pressure (positive vs atmo) gauge is after the lift pump, measuring "blow". Surely everyone here understands the difference between "suck" and "blow".
  11. Capt Ralph
    What does Low Pressure mean to you?
    Lower or below atmospheric or some other value?
  12. Capt Ralph
    A vacuum gauge is a pressure gauge used to measure pressures lower than the ambient atmospheric pressure, which is set as the zero point, in negative values (e.g.: -15 psi or -760 mmHg equals total vacuum). Most gauges measure pressure relative to atmospheric pressure as the zero point, so this form of reading is simply referred to as "gauge pressure". However, anything greater than total vacuum is technically a form of pressure. For very accurate readings, especially at very low pressures, a gauge that uses total vacuum as the zero point may be used, giving pressure readings in an absolute scale.
    https://en.wikipedia.org/wiki/Pressure_measurement
  13. Caltexflanc
    North Carolina
  14. captholli
    captholli Senior Member
    In The Bilge
    Semantics... Marine engineers are taught that any fluid system under vacuum is known as the low pressure side of the system. Discharge side is known as the pressure side of the system. Your getting a bit caught up in the semantics of terminology and thankfully you weren't put on blast for your tongue in cheek post # 10.
  15. Capt Ralph
