Click for Burger Click for Glendinning Click for Perko Click for Westport Click for Westport
Painting a Cracked Hull
Discussion in 'Technical Discussion' started by Soulstice, Jan 20, 2022.
  1. Soulstice
    Soulstice Member
    Portsmouth, Ri
    I am in the process of painting the hull on my 50’ Post. The hull overall looks very good and has always been maintained. Unfortunately when going over the gelcoat with the painter in a test section, we found after removing all of the wax and using a tracing dye, the hull has crazing all over. So now the original plan to sand, fair, paint is out the window.
    I am seeking expertise of the proper way to handle the gelcoat cracking that has occurred in these 2000 era Post, Vikings, Cabo’s, etc. The two options that were brought up to me by the painter are…
    Sand down the hull until the cracks disappear, then continue sanding until you can see the first layer of glass through the gelcoat. Then apply high-build, fair, prime, and paint. They estimated this would eliminate 90-95% of the cracks from returning and individual crazing spots could be easily spot fixed. I am not sure how accurate this is but I have seen spot repairs with AwlCraft done on my buddies boat that were pretty perfect.
    The other option was to grind all of the gelcoat off as well as the first layer of fiberglass, then put one new layer of fiberglass on, high-build, fair, and paint. This process should prevent any cracks from reoccurring although the label is 2-3X.
    From all of the experience here, does anyone have any thoughts on repairing a cracked hull? I don’t know enough about these repairs to know if I am being told everything honestly or if they are trying to hose me as the story has changed a lot over the last two weeks and depending if I talk to the paint foreman or the project manager.
    Soda blast the gelcoat off. Then lightly fair, prime and paint. I sure as heck would not strip a layer of fiberglass off and re-fiberglass. Many of these posts have been fixed and have not gone through this extensive of a deal. You probably could get away with sanding good and high build primer.
    Soulstice and rtrafford like this.
  3. rtrafford
    rtrafford Senior Member
    Vero Beach
    Yes. This. Soda blast, fair, long board, high build, paint. Put the work into the hands of someone you can trust to take the proper steps or those cracks will reappear.
    Soulstice likes this.
  4. Soulstice
    Soulstice Member
    Portsmouth, Ri
    Thank You. This is what I have read in previous discussions from Post/Viking owners that have had their hulls repaired. I was very surprised by their desire to want to strip a layer of glass and replace it. I believe the paint foreman is being extra conservative as they were concerned with preventing the cracks from returning. They are a very good paint yard with lists of experience in the Northeast so hopefully I can sort this out with them.
    I am going to get quotes to soda blast the gelcoat as that will certainly be a much less labor intensive process that sanding everything off.
  5. Tony Garifo
    Tony Garifo New Member
    Freeport NY
    You need to remove the gelcoat. Fair and paint. Major job. Will keep cracking unless all removed
  6. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    I dunno much about it, but I think the next step usually recommended after soda blasting would be (at least one) epoxy barrier coat layer.
    Original post was from back in January, so maybe OBE by now...
    -Chris
    captholli likes this.
  7. captholli
    captholli Senior Member
    In The Bilge
    Sand/grind down to the first layer of fiberglass under the defective gel coat with 40 - 60 grit. Spray/cover exposed fiberglass with 545 epoxy primer, then spray 50/50 mix of ultra- build & high build primer filler within 35 hours or sand the 545 before the ultra-build / high build. Long board and short board in "X" pattern. Use a batten to mark high & low spots. Guide coat and long board - short board again till surface is fair using the batten method. Top coat.
  8. CaboFly
    CaboFly Active Member
    Seattle
    I am finishing up a full sand/prime/paint on a 48 Cabo. Waterline to hardtop. I would ask the yard how many vessels with crazing they have done in the past. If not at least a dozen at this point I would consider finding a yard with more experience regarding this unique issue. Some areas like brow will require almost all gelcoat to be removed where as hull may only have moderate sanding necessary.
  9. Prospective
    Prospective Senior Member
    New England
    This is just speculation but I wonder if your yard knows the history of the cracking gelcoat. Known batches from a specific supplier that failed. Perhaps they are unaware of the history of the gelcoat issue and are concerned the cracking is the result of some failure in the glass? It's common practice to grind out crazing that is caused by flex, reglass, then fair/paint. Maybe this is their thought process and they don't know it's actually a failure of the gelcoat?
  10. BigChief
    BigChief Member
    CT
    I have seen may cracked POSTS, I have seen the total removal of the gel coat and then painted and look great years after. I have seen the sand primer and paint systems. 3 of them up here in the NE and it doesn't work. The cracks come back because the gel coat and a little of the fiberglass still remains which is what continues to Crack. You need to make sure you know what your getting yourself into, who is doing the work and if they know what they are doing.
    Your looking at 100 to 150k to repaint a 50. You don't want to see it crack again in 2 yrs.
    If it was that easy post yachts would not have been bankrupt trying to repair the cracked boats.
  11. captholli
    In The Bilge
    Plenty of information out there online about Cook Composites & Polymers series 953 gelcoat that caused all of the troubles for Viking and Post from 1997 through 2004. Almost every last bit of this gelcoat has to come off as it just isn't prudent to take the chance and leave this 953 on the substrate even if it sands smooth to the touch and to the eye. It really doesn't matter if its light superficial crazing or deep cracking type of crazing as it will print through the 545, Ultra build and topcoat. There are paint contractors that specialized in the removal of this faulty gelcoat but the number of remaining vessels with this problem has dwindled significantly after 18 to 25 years. Most competent marine painting contractors with significant fairing experience can take care of this problem.
  12. Doug Nashold
    Doug Nashold New Member
    Norfolk VA
    Looking at a 2005 Sabre Flybridge Sedan. Can anyone tell me if this Make, Model, and year was affected by the 953 gelcoat issue?
  13. LF4Ches
    LF4Ches New Member
    Chesapeake
    I had a 2003 Sabre flybridge that was very affected by the gel coat cracking & crazing. It’s why I sold the boat. Asked Sabre when they changed away from that product and they couldn’t (or perhaps wouldn’t) answer. Based on my own experience, it was likely after 2005.
