Click for Nordhavn Click for Burger Click for Abeking Click for Westport Click for Ocean Alexander
Overboard macerator
Discussion in 'Technical Discussion' started by Worthy vessel, Jul 30, 2024.
  1. Worthy vessel
    Worthy vessel Member
    Sarasota
    My overboard waste pump, Jabsco macerator model CW532 is getting power but will not run. it was running intermittently and now not at all. Will a new pump solve the problem or is there a switch somewhere preventing it going on. I do have power at the pump
  2. motoryachtlover
    motoryachtlover Senior Member
    smithfield, VA
    On the end of the pump there is slot on the end of the pump shaft that you can fit a regular screw driver in and manually turn the pump. Sometimes this will get it going again. I would use a cordless drill as well. The Jabscos are very problematic to say the least. Pascal recommended switching to a bellows style pump (vacuflush makes one) and that has been a great improvement. I switched out both of my jabsco’s and don’t regret it. West Marine usually carries the Jabsco if you need a replacement.
  3. Worthy vessel
    Sarasota
    Does it matter that I have an electric head?
    Thank you so much!
  4. motoryachtlover
    smithfield, VA
    I don’t believe so.
  5. dennismc
    dennismc Senior Member
    Vancouver BC
    I found that less useage will cause some solidifying of the waste and putting some water down the discharge outlet at the hull side will usually free the pump to start.
    No, those pumps are poor quality, all of them that style and they only last a year or two........ Just replace it. Headhunter are the best ones but have a different size intake hose.
  7. motoryachtlover
    smithfield, VA
    A year or two is about what I got out of mine. Always carried a spare. we ended up switching to larger thruhulls and of course larger hoses to accommodate the larger intake size. Spent a little bit of money but it is so much better than before. We pulled the push button switches that you had to hold down to pump and installed on/off switches. So you can open each thruhull and turn the switches on and pump till empty. With bellows pumps you don’t have to worry about the ruining the pump by running it dry like you do with the Jabscos.
  8. SplashFl
    SplashFl Senior Member
    S. Florida _ Bertram 46
    Replaced a Jabsco with a SeaFlow brand for a LOT LESS dollars last December and so far so good.
    https://www.amazon.com/gp/product/B01G8OQYO2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
  9. Pascal
    Isn’t seaflow a chicom knockoff brand? I wonder how long they last …
  10. SplashFl
    Probably. Prior to changing the macerator pump I replaced the two ER blowers. Again, for a fraction of the ridiculous price of the Jabsco blower I bought a SeaFlow and had a boat mechanic look at it for his opinion. He felt given the new type motor SeaFlow used, it should long outlast the OEM Jabsco. The SeaFlow also had a higher airflow rating. Problem I found during replacement was the mounting holes were not exact. Hopefully they'll both last a long long time.
