Click for Ocean Alexander Click for Nordhavn Click for Northern Lights Click for Delta Click for Abeking
News: Numarine Splashes First 26XP Unit
Discussion in 'Yacht News; Builds & Launches' started by Yacht News, Feb 13, 2018.
  1. First 26XP Unit Launched At Numarine
    The explorer line at Turkish builder Numarine has expanded once again with the launch of the first hull of the 26XP model. Their explorer line comprises the 32XP and 40XP along with the 26XP which originally was expected to be around 24-meters. The design is by none other than Can Yalman and showcases smooth edgy lines that are purposeful in blurring the lines of what an explorer should look like.
  2. Accommodation onboard is for eight guests. Two VIPs, a master suite and possibly a twin are for guests and the repeat client of the yard. Three or four crew members can be slept onboard too on the lower deck. If the interior looks anything like the renders, the internal set up will be showcasing neutral and sandy tones through different materials that offer varying textural values. Longitudinal pattern lines in fabrics features as accent work in many areas of the yachts.
  3. The external decks all have great space for guests to lounge. The aft main deck has a table to see all guests onboard and a similar arrangement is repeated on the sundeck for al-fresco dining. Oversized day-bed type outdoor furniture dots the rest of the sundeck. The aft end of the deck will more than likely be the home for a 6-meter main tender if the dedicated launch crane is anything to go by. MAN diesels are onboard each rated at 1,200 horse power. With her GRP construction one had expect a zippy performance of 22-knots at the top end. If you do not have to get to your far-flung destination quickly and time is on your hands, the Numarine 26XP at stretch a 3,500 nautical range at a fuel-sipping 8-knot autonomy. This new launch is expected to be on display at the Boat Show Eurasia in Turkey which is due to start in a few days (February 17th to the 25th).
    Numarine Turkey
    Gebze Plastikçiler Sanayi İnönü Mahallesi,
    Balçık Yolu,
    Gebze Kocaeli
    TURKEY
    www.************
