Click for Abeking Click for Northern Lights Click for Westport Click for YF Listing Service Click for Cross
News: Maiora Launches 35M "Exuma"
Discussion in 'Unique, Custom or New Launches' started by Yacht News, Jul 6, 2020.
  1. 35-meter "Exuma" Launched By Maiora Yachts
    Maiora Yachts, a member of Gruppo Fipa launched its newest yacht recently, the 35-meter "Exuma". The name alone should hint where this vessel will be heading in the future. Like the model name suggests -Maiora 35-, the vessel is capable of 35-knot speeds although you will find her more often at higher cruising speeds of 26-knots. Exuma is powered by CAT C32 Acerts.
  2. The principle behind the new Exuma is a repeat customer of the yard and they wanted to blend the indoors with the outdoors whether that was via adequate sight-lines, ample glazing or use of low furniture. The master suite is full beam onboard and has excellent views outdoors from both sides of the room. The room's decor follows the general theme around the boat in-terms of style and materials used. There are four other cabins located on the lower deck to sleep a total of 11 persons in five cabins. Wenge, Walnut and Oak are utilized throughout the living areas of the yacht.
  3. The owner has personal touches around the boat and one of them is a wine cellar on the main deck to keep the their Tequila collection safe. Exuma has an internal volume of 301GT more than comfortable and welcoming for the repeat owner and their guests. An interesting feature is the stern where there is nearly full-width built-in stairs allowing uninterrupted views out from the back of the saloon or cockpit area. The yacht has a straight bow and very slim draft to aid in her planned cruising in shallow areas like the Bahamas. LOA is 35.10-meter with a beam of 7.80-meter and draft of 1.35-meters.
    Maiora Yachts
    Via Marina di Levante 12
    55049 Viareggio (LU) Italy
    www.*********
