Click for Walker Click for Burger Click for Northern Lights Click for Glendinning Click for Ocean Alexander
News: Concept Yachts; Infiniti Yachts Infiniti 60 Power Cat
Discussion in 'General Catamaran Discussion' started by Yacht News, Sep 29, 2023.
  1. Concept Yachts & Infiniti Yachts; 60 Power Cat
    Here we have a collaboration between Concept Yachts and Infiniti Yachts to present a ready-to-be-built 18-meter foil-assisted power cat. In fact, the yacht will be built and the two companies are eager on another successful collaboration as they have worked together in the past. They have introduced the Infiniti 36 and Infiniti 52 models before and are now working again with the Infiniti 60 power cat.
  2. The vessel is anticipated to be built in Southampton and will be bear lines that are akin to a coupe on two hulls, sleek and modern. The intended use would be as a dense-liveaboard, sportfishing platform of even a large chaseboat for a superyacht. Onboard customers have a choice of layout with two, three or even four cabins depending on requirements.
  3. The exterior configuration of the boat also comes either standard as the coupe version or with a flybridge so from that perspective there is minimal room for some customization for clients. The Infiniti 60 will be manufactured from resin-infused carbon fiber and remember we said this will be a foil-assisted power cat. The retractable DSS foil will actually come as standard with each boat. The DSS foil is expected to reduce fuel burn for the yacht by as much as 35 percent. The vessel will be powered either electric, diesel or petrol.
    Concept Yachts
    Kerns House, Threemilestone Industrial Estate
    Threemilestone, Truro TR4 9LD
    United Kingdom
    www.*****************
