Click for Abeking Click for Perko Click for YF Listing Service Click for Burger Click for Glendinning
News: 33M Mini Juno Sail Yacht Concept
Discussion in 'General Sailing Discussion' started by Yacht News, May 18, 2023.
  1. Dixon Yacht Design 33-meter Mini Juno
    The 33-meter Mini Juno sail yacht concept coming from the boards of Dixon Yacht Design isn't just a concept it is a proposal that can actually be built if an owner took up the project. The sailing yacht is envisioned with a singular free-standing dynarig mast which we know isn't far-fetched as "Maltese Falcon" was the first sail yacht to utilize this rig setup. The arrangement is also seen on the more recent 106.7-meter "Black Pearl". In short, the rig is one that can be incorporated in reality on the Mini Juno concept.
  2. There was a much larger 100-meter Juno concept from the designer before utilizing the triple mast dynarig system. Mini Juno scales down the idea to just one mast but also has sustainability and Eco-conscious operations at heart. The yacht can be installed with hybrid propulsion with solar panels on the flybridge. While under sail the propellers can act as turbines to generate electricity while the vessel is under sail too. It is anticipated the vessel will be able to sail at 12-knots in good conditions.
  3. Onboard there is a four-cabin layout for owner and guests with three cabins located forward and the full-beam master suite aft with direct access to the beach club area on the yacht. Internally the volume available is in the region of 200 Gross Tonnage. If built, construction would be a mixture between aluminium and composite materials.
    Dixon Yacht Design
    Unit 16, The Boatyard
    Swanwick Marina, Swanwick
    Southampton
    United Kingdom
    www.dixonyachtdesign.com
