Click for Delta Click for YF Listing Service Click for Northern Lights Click for Burger Click for JetForums
Newbie question...
Discussion in 'Carver Yacht' started by Cubsfan, Apr 18, 2009.
  1. Cubsfan
    Cubsfan New Member
    Chicago
    Hi, I'm looking at purchasing my first boat, a 1990 Carver 27' Montego. The boat is in great condition. My question is around the motors. It has Volvo motors, others I see on the internet for sale have Merc motors. Were Volvo / Merc motors an option? The motors have what seem to me to be really low hours (under 200), I'm wondering if they were replaced and the hour usage reset. Also, this boat has a 'wing' (not sure the nautical term:eek: ), the other 1990 models don't seem to have it. By wing, I mean the wing that spans over the helm.
    Thanks for any help / info provided.
    If they are gasoline inboards, there is a 95% chance that they have been changed sometime in the last 18 years. 200 hours would mean the owner used the boat 12 hours per year. It is very common to change straight inboard gas engines with a different brand when repowering. So chances are it had mercruisers like the others and the previous owner got a deal on the volvo's, or the dealer had the volvo's in stock. Gas inboards usually only last 1000-1500 hours of usage. Although I have seen exceptions to the rule.
  3. Cubsfan
    Cubsfan New Member
    Chicago
    Thanks for the quick reply. Yes, they are gasoline inboards, I'll see what service records exist and if they tell a tale.
  4. CaptainMoto
    CaptainMoto New Member
    Kenosha Wisconsin
    CubsFan,
    Referring to a copy of "PowerBoat Guide" is see that several engine options were offered on that boat. I do not have the absolute answer for you, but I suspect Volvo would have been one of the many choices. The reference also has a few Specs: LOA 29'2 , Beam 10'0, Draft 2'10, Weight 6,900#, Fuel 120 gal., Water 41 gal., Deadrise 8 degrees. This deadrise is very shallow and will enhance stability at rest or at non-planing speeds (like trolling). However, if your intentions are to cruise Lake Michigan I would predict a bumpy ride in any choppy conditions. FYI the "wing" is referred to as an arch. Also, 200 hrs on an 18 year old boat is a little suspect, but if you have some info from the owner about it's history it might be accurate. One thing to keep in mind is that low hours does not necessarily = no engine issues. Lack of use and age can be more destructive then constant use. I'd suggest a close inspection of hoses, clamps, belts etc. Internal corrosion can be a hidden time bomb that won't be easy to spot. Take it for a sea trial before you sail off in your dream boat.
    On the bright side, this was a very popular model from 1986-1993. It's got lot's of cabin features not common in boats of that size.
    Good Luck
    Safe Boating
  5. K1W1
    I am pretty sure that the Gas Engine of that vintage are actually Chevrolet engines just marketed as Volvo with the Stern Drive Setup
  6. AMG
    These boats had both 4 cyl, V6 and V8 Volvo Penta engines. The latter usually from Chevy blocks. Then they can be both with raw and fresh water cooling and with Single or DuoProp drives. What kind of engines is it in this boat?
  7. Cubsfan
    Cubsfan New Member
    Chicago
    The boat has two Volvo 4 cylinder engines. The cooling is a closed system. I think I solved the mystery of the arch, the previous owner installed a radar system and probably retrofitted the arch on the boat to carry the radar system. Maybe.
    Thanks for all your replies. We are looking at an old Bayliner and another Carver today.
  8. AMG
    These engines, especially if they have been in the lakes since new, will probably have many years to go. Not too expensive to keep running either.
