Click for Delta Click for Northern Lights Click for Ocean Alexander Click for Westport Click for Cross
New to Yachting - Fuel Level
Discussion in 'General Yachting Discussion' started by Keith C, Feb 23, 2025.
  1. Keith C
    Keith C New Member
    Mobile, AL
    Extremely new to yachting and am still trying to wrap my head around all of the associated costs with owning/operating a decent size vessel. A couple of large expenses I have discovered thus far are bottom-paint/zincs and maintenance. BUT, another cost that I'm constantly trying to figure out is fuel. If I plan on leaving my boat at the marina most of the time (plan to take a short trip once a month for a weekend), is it a good idea to leave the fuel tank full or partially full or what?
  2. Pascal
    If you think bottom paint and zincs are a large expense, I suggest you don’t buy a boat :)
    personally I would avoid leaving fuel in the tank for more than a year. So if you have 1000 USCG tanks and only use 50 gallons a month, don’t fill it up. Talking diesel obviously, not gas, since you mentioned “decent size” and “yacht”
    SplashFl, Keith C and MM3 like this.
  3. Keith C
    Keith C New Member
    Mobile, AL
    Exactly what I needed to know, thank you very much. If there are other common expenses (annually/bi-annually/etc) that you can think of, please list them out. Again, very new to yachting and am attempting to determine what type and size boat my budget and patience allows. My family hopes to utilize the vessel for monthly trips for the weekend and then a few longer stays during the Summer and Fall months.
  4. SplashFl
    SplashFl Senior Member
    S. Florida _ Bertram 46
    Typically, you should figure about 10% of the cost for annual maintenance. I've found fuel is such a small percentage of my costs it's irrelevant. Many owners have been saying insurance has become a problem and since this sounds to be your first boat you should speak to a couple ins. agents as they may not offer coverage if over certain sizes.
    Keith C likes this.
  5. Keith C
    Keith C New Member
    Mobile, AL
    So 10% of the value of the vessel? I completely forgot about insurance. And in my area, insurance is a very touchy subject. I'll reach out to some of my local agents and see what options they offer. Thank you so much for the valuable information as it filled in some gaps that I definitely needed to fill before moving forward in this process.
  6. SplashFl
    Since my last purchase about 2 yrs back I'm sure I've spent a LOT more when upgrades are included and based on the 42 years of ownership of previous boat, those things typically only end when you sell. For example currently contemplating a Water Maker & Starlink. I also fully agree with the post above by Pascal. Also.... if you're able to find an HONEST buyers broker ( word of mouth the best) he/she could be a big help and as in the case with my last purchase, save you dollars and certainly help with the buying process.
    Keith C likes this.
  7. Keith C
    Keith C New Member
    Mobile, AL
    I'm glad you mentioned that because I was thinking that I was crazy for already planning out upgrades on some things on pretty much all of the boats I've looked at thus far. Since I'm in the IT field, the first projects I would like to tackle are things like the electronics and bring in some modern technology. I have heard from a friend that has a fairly new Hatt that if you're not careful, the upgrades can become a constant expense that as you mentioned, only stops when you sell. Have you ever done a rebuild/repower? I'm also concerned about that as I like to plan for the worst and I can imagine that expense being pretty high.
  8. SplashFl
    Never did a rebuild but in previous spt. fish did a repower from her 270 hp. to a pair of 400 hp. diesels. Due to the change in the ratio of the new transmissions had no need to change props or even change pitch of the existing ones so in hindsight got away cheap after selling the take out's. After the purchase of the current toy I had all of the electronics replaced except two of the three VHF's and the auto pilot. Even at that the final was in the $25,000 plus range and just last week replaced both tachometers since the existing digital ones had a "growing" loss of brightness. They were the only two gauges not previously changed. Prior to purchase the seller replaced one of the three AC units, leaving me to deal with replacing the other two. In speaking with two mechanics I would be looking at around $250,000. to rebuild each of the current Man's but they did well in survey and oil analysis so not expecting that need. It NEVER ends till you sell, which I did, but then wound up buying again & starting all over. LOL
    Keith C likes this.
  9. Keith C
    Keith C New Member
    Mobile, AL
    Sorry for the long delay in response. I fell on the floor when you mentioned $250k to rebuild MAN engines (each, right?). If rebuilding is that high, it makes me wonder how much new engines would be?
  10. SplashFl
    Yeah it's insane. That was also the "ball park" replacement cost I got at the Man booth at the Ft. Laud. boat show 2 yrs back. One of my diesel mechanics said if not in a rush Man parts can be purchased via a 3rd country, knocking off around 30% of those costs.
    Keith C likes this.
  11. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    What size, type and vintage of boats are you considering? @SplashFi gives you a good rule of thumb at 10%. However, that can go up dramatically depending on the vintage and condition of the boat you buy. Same issue with insurance. Older boats are getting harder and more expensive to insure. And if you have no operating experience in a similar sized boat you likely won't get insurance without hiring a Captain until you have enough hours that insurance companies get comfortable you know what you are doing.
    Keith C and SplashFl like this.
  12. Pascal
    It really depends on the boat you are looking at so it would help to know if you re looking at a 50’ cruiser or something bigger and high performance like sportsfish. Cost can vary by 100 to 200% depending on engines. Air con type, generator, etc.
    Also ease of access is critical… if some systems are hard to reach, what should take 1 hours can take 8 hours. At the average labor rate of $100/120… you do the math.
    repowering is obviously more expensive but sometimes it makes sense. A few years ago I repowered my Detroit powered 53 Hatteras with factory reman Cummins (435hp C series) That was about $110k vs $75k for a full rebuilt of engine and gears.
    Cummins and now cat have a great factory reman program with warranties so you get virtually engines for a lot cheaper.
    some engines cost a lot to maintain than others. Man and MTU for instance vs Cat and Cummins.
    As to electronic upgrades, you need to be realistic about your needs. I recently upgraded to new 9” Simrads as well as a new Simrad autopilot… about $3500 altogether. I did the install my self. not rocket science. Planning on adding a radar a AIS soon… the whole package isn’t the best and doesn’t have the biggest flashy screens but for a weekend boat it works just fine.
    I could go on and on… when you narrow down your choices, give us details.
    rocdiver and Keith C like this.
  13. Capt J
    You can buy a lot of water for the price and maintenance of a water maker on your size boat. I'm an FCI authorized service. Starlink however is absolutely worth it however.
    SplashFl likes this.
  14. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Seems odd. Our MAN guy said he thought we could replace our current 900-CRMs with new I6-850s (including gears) for about $200K. ~$85K each for the engines/gears, wild stab at labor. Reduce propulsion weight by a couple thousand pounds. Then hope for decent return selling the take-outs.
    No way that would make any sense at all, of course, assuming no catastrophic failure... so it was mostly a blue sky discussion...
    (Maybe your guys were meaning ~$250K replacement for both? Not rebuild, not each?)
    For OP, that 10% figure is often only about the best WAG folks can offer... and it can vary lots depending on boat, systems, etc.... and even then, expenditures can swing wildly from year to year. Especially in "upgrade" years, or when replacing major systems (ACs, water heater, etc.) and often also depending on labor costs -- yours ("free" -- but not really) or hired ($85-175/hour, depending).
    When we were shopping, it looked like Cats the same size as what we ended up with would cost about the same to maintain. Periodic aftercooler replacement, stuff like that.
    Our previous boat had the same Cummins 6CTAs you repowered with. I liked 'em, relatively inexpensive, as you say. OTOH, they were also 8.3L vs 14.6, 450-hp versus 900... and I guess size matters. Looked to me like most of the electronic engines in the 14-15L range, any brand (without me having any actual experience on others), would cost about the same to maintain: lots. Or at least more than 6CTAs.
    -Chris
    Keith C likes this.
  15. Pascal
    as with everything it all depends on how you use the boat. I wouldn’t go to the Bahamas without a watermaker unless you spend almost every night in a marina. Even in the US, if you spend more than a couple of days on the hook, you may have to limit water use after 2 or 3 days in the hook. Not worth trying to save $4k for a 25gph basic unit.
    as to Starlink, It s been 3 years now since we switched and it’s been a game changer. We just came. Back from 2 weeks in the Exumas and we didn’t loose service once
  16. SplashFl
    Despite things mostly costing more down here seems like too large a difference for both prices to be correct but rather not even think about a repower at this time.
    MBevins likes this.
  17. SplashFl
    The electronics company that did all my upgrades said I would have to purchase Starlink but they could then do the install. For the time being business is keeping me near home so until another time, it will have to wait.
  18. DOCKMASTER
    Ketchikan, Alaska
    I spent the money on a watermaker and I never use it. It has been been pickled for two years now. I installed the watermaker then upgraded my heads to the Raritan macerator units and opted for the freshwater/seawater selectable option. I just switch over to seawater for the heads when we leave the dock. We go out for 3-4 days without any issues on water now. I also switch my fish box ice to seawater. I'm really only using freshwater for dishes, coffee and showers. We usually only use about 1/2 tank now. I do like the piece of mind knowing I can make water if I need to. I suspect my watermaker will get used next time both of my adult daughters are aboard though :):)
    Keith C likes this.
  19. Keith C
    Keith C New Member
    Mobile, AL
    Yesterday was spent contacting nearly every insurance agency I could find and every single one of them replied with:
    "we have taken a look at your information, but at this time we are unable to locate a market that would provide us with a proper quote for your vessel"
    The quote requests I submitted were for a 2000 Azimut 70 and only 1 company asked if I would be hiring a captain. I asked if it would make a difference if I were to hire a captain and this was their response:
    "On a 70' vessel the majority of carriers would always require USCG License Captain to operate the vessel"
    So it sounds like I have to work my way up to a 70 footer? My dreams of owning something bigger (114-foot Hatt), seems to be one that will have to be put on hold. Will I have any luck with a 65 footer? To answer your question, I'm interested in almost anything, but I am superficial apparently and as I'm scrolling through listings, if the boat isn't "pretty", I'll scroll right past it. Some of the ones that catch my eye:
    2000-2007 Azimut 70 Sea-Jet
    2006 Ferretti Yachts 881
    1994 Hatteras M/Y 114 (specifically, Lady Audrey in Australia) - pipe dream apparently
    2006 Viking Sport Cruiser 70 M/Y
    1990 Viking Cockpit M/Y
    1972-79 Hatteras M/Y 72
    2001 Maiora 20
    Any Trawler
  20. SplashFl
    Yeah, my daughter loves LONG hot showers and she's used to unlimited water. The heads are on fresh. In previous boat I had a set up to run off salt when away from the canal but had to always rinse with fresh when done with the trip or the stink took over.
    Used to have a small hand operated water maker in the ditch bag but despite it being pickled wound up trashing it after learning the membrane was probably shot due to too many years since being pickled. Will probably not go for a new installed one since extremely rare to ever be on the hook but I do need to hook up the drinking water hose and make sure the boats pressure reducing inlet is good.
    Keith C likes this.
