Click for Northern Lights Click for Glendinning Click for Westport Click for Burger Click for Walker
New Models: Monte Fino "S" Range
Discussion in 'Yacht News; Builds & Launches' started by YachtForums, Nov 24, 2009.
  1. New Models: Monte Fino "S" Range
    The Kha Shing yard has been busy working with US based Setzer Design Group
    on a new 19-meter and 34-meter design for the new Monte Fino S range.​
    The all-new MFS 62 will provide 30 plus kts by using Pod-Drives. With a beam of 5.3m and a relatively shallow draft of 1.1m, the vessel still holds 950 gallons of fuel and offers a variety of cruising speeds with ranges based on the final power plant selection. The yacht includes three staterooms below, one of which is a full-beam master. The galley is half a level below the main deck and includes the salon and pilot area under a retracting sunroof. The aft deck includes a sunning pad and dining areas and access to the engine room or an optional crew lounge and cabin below. The swim step is accessible from either side, and lifts to reveal a tender garage positioned above the engine space. A flybridge version will be offered as well.
  2. The all-new MF-S 112 addresses traditional yachting needs with a fresh and refined style. With plenty of volume to accommodate large fuel and water stores, as well as generous cabins for owners and guests on multiple levels, this new design offers up a new look complete with all the expected amenities. There are three guest staterooms and one master suite below while the crew cabins and lounge are still placed aft of the engine room. A galley and open lounge are forward on the main deck and a generous salon and dining area are aft of the pilothouse central zone. An oversized main aft deck is an important feature of the design with its large dining area, bar and sunning lounge. The flybridge is multi-level and includes seating, a bar, grill and hot tub amenities. The interior can also be customized based on owner’s needs. With a beam of 6.9m (22'6") and a draft of 1.9m (6' 3"), this hull form will hold ample fuel stores for extended cruising and yield top speeds from 16 to 26 knots depending on selected powering options.
    For more information contact:
    Kha Shing Enterprizes
    10 Kuang Yang Street, Hsiao Kang,
    Kaohsiung 812, Taiwan R.O.C
    Tel: 07-8020345 #111
    http://www.khashing.com.tw/index.asp
