Click for Northern Lights Click for Abeking Click for Burger Click for Delta Click for YF Listing Service
New Inverter issue
Discussion in 'Electronics' started by Capt Ralph, Nov 13, 2023.
  1. Capt Ralph
    We have been off the dock for several days. Headed south and anchored in the N/W corner of Lake George behind Drayton Island.
    The weather was cool and A C was not needed.
    Inverter was set-up to start the lil gen-set when its batteries got low.
    TVs, Computers, 115Vac lights, Crock Pot, Coffee maker, Micro-wave oven, Refrigerator & Ice maker were all working great. 2 days later, the inverter batteries were still delivering very well.
    We were all so happy the inverter was running so fine for so long with its new batteries. No gen-set running. 1 to 2+ GPH diesel fuel not consumed
    Then little things were noticed; The Raritan Crown head started running slow, DCv lights were not as bright, DCv potable water pump a lil weak.
    Then AIS sounded a strange alarm. A GPS repeater went blank. A depth sounder went blank.
    We forgot about the ships main batteries. Both 32V banks run the house demands and were dead (port) and low (stb).
    A DCv to DCv converter keeps a 12V electronics battery charged from the stb battery bank when a gen-set is not running also.
    In near 20 years, never had this problem before; inverter batteries lasting longer than the house batteries.
    Well, out of HOT water anyway, Gen-sets have their own battery, Lit one up and all back up quickly and a nice hot shower after dinner.
    So, not really an inverter problem but a new issue because of a too-good inverter system.
    Next;
    I don’t want to run either 40A battery charger thru the inverter but I can not find any 32V, low current, battery trickle or maintaining chargers.
    Anybody have any lead s or ideas?
    I had 16 batteries before, now down to 14.
    As much as I recommended a house bank to others when they can, I'm not going to create a 32V house bank here.
    No room, and the boat is on a diet.
  2. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Not sure I understand the problem. Or maybe the severity of the problem.
    You ran the house DC loads for "several" ( or at least a couple?) days without genset/battery charger recharging, yes? What's wrong with just starting the genset once/day (or however often is required) to recharge main batteries? And make hot water at the same time...?
    -Chris
  3. Capt Ralph
    Thank you four thoughts
    Well, your idea is what we ended up doing, twice.
    Butt;
    Unlike AGM batteries, these starting & house flooded batteries are not the type I would want to discharge down much, nor often.
    Was searching for a low current 32v trickle charger that would not burden the inverter much.
    Just some way to help the 32v banks until we start the gen-set as needed for hot water or stove/oven cooking.
    Have some weather coming in on us. Sadly, back on our dock last night.
    As soon as we can, were back out on the river to enjoy this pleasant temp weather.
    It is so quiet and calm with out a gen-set running.
  4. ranger58sb
    Chesapeake Bay, USA
    Well, normally I'd just consider the batteries as consumables... with expectation to service and replace as necessary. Maybe 8V batts don't grow on trees, though? OTOH, I've read there are golf carts that use 8V batts, so maybe that suggests they're not all that difficult to come by?
    I don't suppose there might be some 8V AGMs lurking around out there somewhere?
    By trickle charger, you mean a DC-to-DC charger? 32V versions don't exist?
    It would indeed seem a bit odd to use your inverter bank and the AC charger to top up your main banks, even if doable, given loss to inefficiencies along that path. Maybe just bite the bullet and fire up your genset more often? And enjoy the hot shower that comes with it?
    -Chris
  5. Sea Gull
    Sea Gull Member
    CT
    I don’t understand the logic of an inverter bank separate from the house bank, especially with the auto genset starting feature. If you combine the two banks of batteries you’d get that much more reserve and monitor the whole system voltage, automatically charging when necessary.
    On the other hand, getting in the habit of running the genset manually once or twice a day at the times you choose is what most of us have been doing all along.
  6. ranger58sb
    Chesapeake Bay, USA
    Boats are sometimes (often?) built with two main dual purpose bank, each starting one engine and servicing approx. half of the house DC loads.
    It's sometimes (often?) easier to add or repurpose another battery bank and add an inverter to service house AC loads. (Our setup is like that; our thruster bank now also occasionally powers a few house AC loads via inverter.)
    I've guessed Ralph's situation is similar... and I guess his is also more complicated by having 32V start and house DC systems... with a 12V or 24V AGM bank to do that inverter thing.
    -Chris
    Capt Ralph likes this.
  7. Pascal
    Having a separate inverter bank means none of your critical house loads will be compromised especially bilge pumps. This is especially important with automatic inverters which will kick in if shore power fails. Ex you re away from the boat, your dock side breaker trips, inverter kicks and runs down your house bank. No bilge pumps left.
  8. Capt Ralph
    Yep, I have a mess below.
    Two 32v banks for the engines and split house as you said.
    Two 12v batteries for electronics and gen-sets.
    One 24v bank for the inverter.
    Always had an inverter. Mostly for when the boat moved, it could push air thru itself, no need for a gen-set while running.
    Small inverter bank was kept up with a second alternator mounted on the port engine. Fridge (beer) cold, computers, TV, lights and more ran un-interupted.
    When we could, gen-set off at night. The next morning the inverter batteries may make the coffee , may roll over and die.
    I had to fix this.
    For almost 3 years I have been working on this newer inverter system. 230Vac @ 4kw from 24Vdc. Was considering running our cabins AC unit on it.
    All these years, all the expense, all the fine tuning and I never considered the house batteries would die before the inverter batteries would.
    So, my big issue now; not to damage my fresh flooded house/starting batteries.
    I'll have to dock side experiment and find how long the house/starting batteries can run before their state of charge (SOC) lowers to a damaging level.
    First SWAGs, not long.
    Then determine how long till their back to 100% SOC.
    AND for now;
    Start a gen-set to keep the 32v battery banks healthy, probably daily (or as needed).
    Later;
    So, instead of connecting a AC unit, I may have to connect one of my big asp 32v chargers to it.
    It appears no such thing as a 32v batter maintainer (auto trickle charger).
    If I can find one (& can afford it), I'll install a 24V/32V DC to DC converter.
    Frak,, this may accelerate my conversion to all 24v. Was not planning on this for another 20 years.
    Maybe I'll start another Go-Fund-Me account for this. ;);)
  9. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Did you ever do the bridge removal you talked about ? If so, park some solar up on the roof.
  10. Capt Ralph
    No, Everything still up there.
    Still, even with panels, I would need a 32v solar charge controller.
    And, the green on the money tree is near gone. I hope some of that green comes back in the spring. That green seems to have shorter seasons these days.
    I'm just going to have to run the gen-set every evening on these comfortable days.
    Figure when near 100% SOC and turn it back off.
    Now, when we travel to the keys or islands, It's hot, ACs and water makers are running.
    One of the gen-sets is always running unless we sleep on the deck (that we do when we can).
  11. Capt J
    Just run the generator for a few hours each day or buy a sailboat and live without. Electricity isn't free and there's no free lunch. Even when your main engine alternators are charging those deeply discharged banks, they're using the same amount of extra diesel to turn the alternators when they're putting out those kind of amps.
  12. ranger58sb
    Chesapeake Bay, USA
    We do that anyway, partly because our galley is all electric so we time genset usage (and battery recharging) to coincide with (cooked) meal times. And we make hot water for showers at the same time. We don't try to reach 100% SOC, though; just take whatever increase we can get in the time allotted... and then eventually head for the dock for a couple days to recharge to 100% on shore power
    There might be another possibility to mitigate your existing situation. If you have space, you could maybe just add another pair of 3x 8V batteries in parallel to each of your existing 32V main banks. Doubling capacity on each of those might be significantly useful.
    I see there are 8V AGMs out there (who knew?). That could conceivably let you use non-standard orientations to double the size of each main bank. (And would reduce service issues, if access for watering isn't all that easy.
    If all your current 8Vs are essentially the same brand/size/age/etc. then maybe combining those into a single bank, making up a new bank of 6x new 8V batts for the other side could be a way to manage the cost.
    Of course it's easy enough for me to spend you money.
    -Chris
  13. Capt Ralph
    I luv spending OPM (other peoples money) also.
    AND, thank you for your thoughts,, but no.
    It is 4 x 8v for a 32v bank.
    I have no more room for any batteries.
    Boat is on a weight diet. Adding a mile of 3/8" G chain did not help much. 6 inverter batteries really tipped some scales.
    Adding batteries requires a healthy money tree that is currently bare and bent over.
    If the green comes back in the spring, it would be cheaper, lighter & longer living; to have a 32v charger custom built (ACv to DCv or DCv to DCv). But then, my fuel budget gets zinged (again).
    So, As you and others have stated, just run the gen-set a lil each day.
    But this just bums me; fancy asp inverter system, that works great, and I still have to run the gen-set. F M
  14. ranger58sb
    Chesapeake Bay, USA
    Erp, sorry, I see I typed the math wrong. But I get your points.
    Maybe a consolation is that you might not have to run the genny as often or as long as before... depending...
    But at least it's not a horrible situation.
    -Chris
  15. Capt Ralph
    No, far from horrible.
    Just crappy humorous. :D:D
  16. Capt J
    If you ever want lithium batteries, let me know, I'm a Dakota Lithium dealer and will give you great prices. They're perfect for an inverter bank due to being able to safely discharge them 90% and also having 3000 cycles versus 300 and 5 year free replacement warranty 11 years pro-rated, and being lightweight.
  17. Pascal
    Where are they manufactured?
  18. Capt J
  19. Pascal
  20. BlueNomad
    BlueNomad Senior Member
    At Sea
