Click for Northern Lights Click for JetForums Click for Burger Click for Westport Click for Walker
2004 Meridian 408 with 9' Custom Extension
Discussion in 'Yachts Up To 49'' started by David Siegel, Jul 26, 2023.
  1. David Siegel
    David Siegel New Member
    Newport RI
    2004 Meridian Motoryacht
    Asking $439,900 THIS IS A ONE OF A KIND VESSEL
    $320,00.00 IN UPGRADES TO THIS VESSEL!
    PRIME TIME is an upgraded Meridian 408 incorporating an extended 9' aft cockpit/swim platform to bring her length to over 52 feet. The aft cockpit was designed in keeping with the aesthetics of vessel lines for a seamless look, and she is in turn-key Bristol condition. Carefully crafted with the highest levels of technology and comfort for enjoyable cruising, PRIME TIME has received numerous recent upgrades, including state-of-the-art electronics, high-fidelity sound, and more. She has been meticulously maintained and upgraded by the owner's son, an electrical engineer with ABYC certification who works in the marine industry, and her recent insurance survey indicated no recommendations (available upon request). Low engine hours appx 750 Port and Starboard.
    50' Slip at Newport Marina in Newport RI. available for purchase with purchase of vessel. Slip is on end of finger pier with great views of Newport harbor. Slip is easy in and out. No 50' slips available in all of Newport. Newport Marina is the best marina in Newport with pool and bath/shower facilities.
    KEY FEATURES AND UPGRADES:
    • Extended 9’ aft cockpit (LOA 52’) with built in curved seating, teak table, stereo speakers, fridge and electric grill
    • Recent electronics include, two Garmin chart plotters, Reactor auto pilot, Class B AIS, 6’ Doppler (Fantom) open array radar and Airmar solid state weather station on top of mast. All original analog gauges converted to digital displays
    • Glendinning electronic throttles with joystick control. Vessel came with mechanical separate throttle and gear shifter
    • Garmin forward looking sonar to avoid underwater shoals and/or objects
    • Zipwake interceptor trim system with built in GPS to provide perfect trim for maximum speed and efficiency
    • FLIR night vision camera pan/tilt
    • Two KVH domes allows each TV (4 in total) to tune to different channels at the same time. Separate KVH offshore internet dome
    • Upgraded 24V Bow and stern thrusters 10 min. continuous run time (stock thrusters 12V had much less power and would thermally shutdown after 30 sec)
    • Six state-of-the-art underwater Lumishore lights with infinite colors, aft cockpit color screen controller and salon iPad computer DMX controller
    • Six JL audio speakers and two subwoofers. Fusion stereo head unit with two full color remote stations on each level. Salon 5.1 Yamaha home theater with 32” 4k TV
    • Key fob remote control security system with blinking LED at all entrances. Aft pan/tilt camera on mast, 2 forward 2 aft DVR recording surveillance cameras which can also be used for docking.
    • Flexiteek on gunwales, bow, upper and lower cockpits
    • Impeccably maintained Recent survey no recommendations
    Navigation Systems
    Navigation Equipment
    The helm's electronics and controls are truly state-of-the-art. The separate throttle and transmission controls were replaced with an electronic Glendinning single throttle with sync and docking modes. Also added was a joystick control for docking.
    Given that the original electric bow and stern thrusters thermally shut off after 30 sec. of continuous run, this was not suitable for joystick maneuvering. Both bow and thruster stern thrusters were upgraded to 24-volt long run time (10 min continuous run) Vetus thrusters. The 24V battery system has its own 24V charging system. The original thruster controller was replaced with a dual joystick design for easier use.
    Mast
    Two KVH TV3 satellite domes are mounted on each side of the mast which provide 4K TV. A third dome is a KVH LTE1 which allows for up to 25 miles offshore internet connection. Also on the mast is the latest Garmin Fantom Doppler radar with 6’ open array antenna. GPS, Sirius weather and AIS equipment is also mast mounted. The mast can be illuminated at night with white, red or blue light.
    All electronics were replaced with two Garmin chart plotters and a Garmin Reactor autopilot with an electronic compass. Analog tachs were replaced with Aetna digital tachs. Analog engine gauges were replaced with digital LCD display screens. The radar is the latest Garmin 6' open array Fantom Doppler radar. A fully articulating FLIR night vision camera system has also been added. The original Bennett trim tabs were replaced with Zipwake interceptors which utilize a built-in GPS to set them for maximum performance, at the helm is the interceptor LCD controller. The vessel has a Garmin AIS with an emergency button. VHF Garmin radio is new. Sirius weather antenna is on the mast. For real-time weather (wind speed, direction, and other parameters) an Airmar solid-state weather station is on the top of the mast. Weather is displayed on an additional Garmin screen (GMI 20) which helps when docking in windy conditions. The spotlight has been replaced with a Jabsco wireless control on the helm for pan tilt and changes from the spotlight to floodlight modes. This vessel even has a Garmin forward-looking sonar to help in shallow waters.There is a pan/tilt aft-facing camera to assist in maneuvering, which can be displayed on either of the Garmin chart plotters or on the TV.
    577016_20230725103608766_2_XLARGE.jpg 577016_20230725103608786_4_XLARGE.jpg 2793266_04fbd1ae_33.jpg 8676803_20230207123535066_1_XLARGE.jpg
  2. David Siegel
    Newport RI
    Deck and Hull Equipment
    Aft Cockpit
    The aft cockpit was professionally installed at Newport Shipyard in 2014. An engineering study was completed by Gurit (a Danish firm specializing in marine construction) relating to the attachment and construction of the project. Since 2014 the aft cockpit extension has performed flawlessly. The vessel underway with the extension is stable and performance is excellent. The extension includes a built-in curved couch with Sunbrella nautical-themed stripes which match throughout the vessel. All exterior cushions have closed cell foam for no water absorption. A teak custom inlaid epoxy coated table adorns the sitting area. A port-side refrigerator is built into the extension bearing the Meridian logo engraved upon the door. Above the fridge is a clever pull-out electric grill. Multiple storage areas are under the couches. At the stern of the platform is a large hydraulic hatch for additional storage. The rear of the extension has a swim platform with a hatch for stowing the flip-out telescopic ladder. Appropriate cleats are attached to the platform.
    Upper Cockpit
    The upper cockpit has a couch which was installed as this space on a standard 408 is vacant. It has upgraded Sunbrella fabric which matches all other cushions. The couch has storage under cushions and a storage compartment. The couch has stainless cupholders. Across from the couch is a sink with storage cabinets for liquor bottles and a full-size ice maker in the adjacent cabinet. The port and starboard clear curved windows were originally plastic and were easily scratched and were replaced with tempered glass. Also in front of the couch is a custom epoxy-coated teak table on a hi/low base.
    Deck Equipment
    All exterior gunwales, bow as well as upper and lower cockpits and swim platform have Flexiteek installed. It looks just like new teak without the upkeep and maintenance teak requires. A clever design to hide the cable and water hose includes two hatches on the cockpit floor which contain them for no tripping or unsightly cables in the cockpit. The Meridian name boards were originally plastic which during buffing were susceptible to damage and were replaced with highly polished solid stainless-steel.
    The anchor is the highly regarded Ultra Anchor with its optional swivel, so the anchor always comes up in the proper position. This famed Turkish stainless steel anchor's design holds ground better than any other anchor in it’s class. The first 5 feet of chain is polished stainless steel, so it looks great being visible up at the windless. The plastic anchor control covers on the bow have been replaced with polished stainless-steel covers.
    Additional Equipment
    Entertainment Equipment
    This vessel has a stereo system designed by a high-fidelity expert. It has a Fusion large screen LCD head unit at the helm and two remote LCD panels on the upper cockpit and one at the lower cockpit for full control. The Fusion remote units are on the NEMA network, so they can display any NEMA data, such as wind speed and direction. It has JL audio speakers through the exterior of the boat with two 12" subwoofers. Amplifiers power each of the speakers with clean power.
    Galley
    The Galley has a large Kenyon cooktop as well as a large refrigerator, freezer, and microwave. The galley also has plenty of counter space for enjoyable onboard cooking.
    Mechanical Equipment
    Engine Room
    All lighting in the engine room is LED. All maintenance is up to date, including the cleaning of the after coolers (port side aftercooler is new) and heat exchangers. Sherwood water pumps have been upgraded to the more dependable SMX pumps with easy-to-change impellers (not using splines or key way) but a special tool to make removal and insertion easy. The boat has a Reverso electric oil changer system. All seacocks have Groco valves which allow for pull-out plugs for easy winterization. The original float design for waste tank monitoring has been replaced by an ultrasonic device for accurate readings without the usual issues a float presents. Waste level are displayed on digital monitor.
    Air Conditioning
    All four A/C units have been replaced recently with new Cruisair units. These units have plastic pans which do not corrode or leave rust stains down the side of the boat on raw water outlets. The A/C pump is oversized and new as of 2020.
    Electrical Equipment
    Generator: Onan 9 kW Model 9MDKAV-2743
    The interior electrical panel like the rest of the vessel has been fully upgraded with numerous LCD panels for all conditions of the boat and battery charging systems. Since some of the displays are on the NEMA network even all weather information including wind speed and direction can be shown as well as any other NEMA data.
    Underwater lighting is also state-of-the-art. All lights are Lumishore with infinite color-changing capabilities. There are four large lights on the stern and two lights one on the port and one on the starboard side. A computer mainframe controls all the lighting with a DMX controller like those used at rock concerts for multiple effects. An LCD Lumishore light control panel is on the platform extension. Control can also be done with an iPad using custom software. The Custom stainless vessel name "Prime Time" also lights up and is interfaced with the DMX system and can be synced to follow the colors of the underwater lights as well as many other lighting modes. If the name of the boat changes, the existing wiring can be used for new vessel name.
    Even the horns have been upgraded to Khalenberg air horns loud enough to get the attention of any size vessel.
    The vessel has an alarm system with all exterior doors as well as a contact that sets off the alarm if the canvas cover for the helm electronics panel is removed. There are 4 blinking red LEDs at all entry points when the alarm is armed. A keyless wireless remote arms/disarms.
    The Vessel has a new 2021 ACR full-size EPIRB.
    Salon
    The salon has two opposing couches with the port side couch having 3 pull-out footrests. Storage is under the starboard couch. All woodwork throughout the boat is cherry and in outstanding condition. All carpeting in the boat is excellent and stain-free. The salon has a 32" 4K HDTV with a Yamaha receiver and Dish Network equipment hidden in a cabinet. Four speakers are in the salon, with two subwoofers under the couch for surround sound. There is also a CD changer with AM/FM radio under the TV.
    Stairs leading to the galley and bow stateroom lift up where the washer/Dryer and central vac system is located.
    Accommodations
    Owner Stateroom:
    The owner's stateroom is a few steps down from the salon back aft. The stateroom provides ample hanging closet space, a large bed with easy access on both sides, a large window for plenty of light into the aft cockpit, a large head, and a separate shower space.
    VIP Stateroom:
    Forward of the galley is the VIP Stateroom with ensuite head, sink, and a separate enclosed stall shower. There is a separate door leading to the head from the salon for “day head” access. The aft-facing sleeping area has easy accessibility from port or starboard and plenty of storage lockers/closets.
    Helm Area:
    Above the salon is the helm area and lounge. Visibility is excellent and incorporates plenty of seating, a fridge, and a large flat screen TV on a movable hinge. The flat screen TV can be rotated to face either the helm or the upper cockpit. For ease of maneuvering, the TV, when facing the helm, can display port and starboard views of the sides of the vessel at the same time on a split screen.
  3. David Siegel
    Newport RI
  4. David Siegel
    Newport RI
  5. David Siegel
    Newport RI
    Continued
  6. David Siegel
    Newport RI
    continued
    577016_20230725103609362_17_XLARGE copy.jpg 577016_20230725103608987_25_XLARGE copy.jpg
  7. David Siegel
    Newport RI
    Continued
    DMX system for underwater lights. Professional system used for rock concerts. You can customize the lighting to any sequence or color you can think of. Can be controlled by ipad or on salon TV both shown below.
