Click for JetForums Click for Burger Click for Walker Click for Westport Click for YF Listing Service
Man vs. Caterpillar Diesel Engines
Discussion in 'Engines' started by karshar, Jan 3, 2008.
  1. karshar
    karshar New Member
    Dubai
    HI!
    Need to decide on the Engines for a 145' Wooden Yacht, have MAN V12-1550 and CATERPILLAR 3512 in mind.
    Any feedback would be good. Have experience with Caterpillar but not much with MAN.
  2. The Reverend
    The Reverend New Member
    La Paz Mexico
    8 out of 10 owners prefer Cats!
    With previous generations of engines in my opinion Cats were much easier to look after.
    However it would be wrong for me to give uninformed opinion on these engines.
    Surely there must be someone here who can answer this very sensible question.
    K1W1 isn't this an area you specialise in?
  3. K1W1
    Yes Reverend it is an area where I have great expertise as you well know :).
    If I were offered a 3412 developing 1550 HP I would be looking at another brand of engine or a CAT with a few more cylinders and a larger bore and stroke.
    10 yrs ago I have had a lot of experiences with a pair of 3412E's rated at 1350 HP, the most enjoyable experience was when I didn't have to deal with that boat anymore
    CAT's have my support for the most part as they are generally easy to work on as the Reverend says, they have good parts availability worldwide and they are very reliable with the exceptions being the highest output ones and the CAT C9 in all configurations and arrangements.
  4. marlin2008
    marlin2008 New Member
    Galveston and Freeport, TX
    Cat's or Manns
    I have had the pleasure of running cats, cummins, and manns......
    If you want to reach deep in your pockets each time you need maintenance go for the manns. If you like availibility of parts and reliable power go for cats.
    I would also take a look at the new cummins.
    There has been a great deal of performance changes to engines over the past few years due to the addition of electronic engine controls.
    Best advice overall.... "Get the biggest bang for the buck".
  5. karshar
    karshar New Member
    Dubai
    Thanks Guys for the feedback. As I had said have experience with CATS and know they are reliable and also have good service world over, just wanted to be sure.
    Coming to Marlins suggestion am also looking at Cummins engine model KTA38-M2.
    In this part of the world i.e. Dubai caterpillar has been very strong traditionally both in commercial and Pleasure section especially above 1000 HP.
  6. lwrandall
    lwrandall senior member
    Baltimore
    MAN CR vs CAT ACERT
    I have been wondering about Man vs CAT for a while. Didn't MAN develop common rail technology? How are their CR engines comparing to the CAT ACERT ie: sound levels, vibration, smoke and efficiency. Lastly, are Non-ACERT engines any more or less reliable, see above list, than the ACERT engines.
  7. K1W1
    Here is a bit about the history of CR Injection
    http://en.wikipedia.org/wiki/Common_rail#History
    MAN didn't develop it at the outset but they certainly are using it with solenoid controlled injectors from what I have just read online.
    CAT has the ADEM 4 ECU these days which is a pretty smart piece of kit.
    Karshar- Can you still buy a new 3412 E out there in Dubai?
  8. CaptPKilbride
    CaptPKilbride Senior Member
    On the water
    Why are you looking for engines more suited for high speed motoryachts to install in a 145' wooden yacht?
    I imagine it will be a displacement hull, correct?
  9. JTS
    JTS New Member
    Hudson WI
    K1W1;
    Can you expand on the problems with the C9? I have a pair I put in service in 2005. Only have 350 hours and now out of warranty. What should I anticipate or what are the weak points?
    Thank you,
  10. nilo
    nilo Senior Member
    Istanbul
    I have used 2 Cats (one of them 32 Acert I am still using and have around 500 hrs) and I have used 3 M.A.N's. (non of them common rail). I had more problems with Cats compared to M.A.N., but everytime I had a problem with Cat's there was good service. Service levels of M.A.N. was also very high in Turkey.
  11. K1W1
    JTS- You have a PM that will hopefully answer your questions.
