Click for Burger Click for Cross Click for Nordhavn Click for Westport Click for Abeking
Looking to commission a working Model of yacht
Discussion in 'Yacht Designers Discussion' started by Longranger5, Mar 11, 2010.
  1. Longranger5
    Longranger5 New Member
    Asia
    Hi All designers,
    I am looking to commission a working model of a 85m yacht of which i love the design. I am looking at a scale of 1:100 to 1: 80.
    By working, i mean the engines and rudders should run on batteries and work with remote control. Maybe some lighting for special effects, nothing more.
    Do any of you know where i could get such a model made? Who does the models for the yacht builders?
    Thanks in advance.
  2. CODOG
    CODOG Senior Member
    Bournemouth, southern England
    There is a massive amount of scale model boat enthusiasts all around the world. Many many web sites and forums specific to RC model boats too. I'd suggest having a look at a few on-line model forums and see if you can find one that you think is fairly switched on, join up and ask some questions. In my experience they are an enthusiastic bunch:)
    The larger yacht builders all have their own contracted model makers, all under heavy confidentiality agreements. If you want an exact model made of a particular yacht, your first problem is getting hold of enough design information for the model to be made...this wont be possible from a company under the above confidentiality agreements, but there are model makers out there who can make a model that at least closely resembles the yacht in question from photos and basic information available on line.
    Your second problem will be how the model is to be made.
    A one-off model will be expensive, whether its made from GRP / FRP out of a mould or scratch-built from plywood etc. A lot depends on how complicated the superstructure is etc. Either method can be built from conventional 2-D drawings, or 3-D design information.
    I've seen some spectacular RC model yachts built both ways. These days its quite common for model making enthusiasts to utilise CAD/CAM. The initial design is created with 3-D software, and the tooling required to make the moulds are machined direct from this 3-D info.
    3-D design information can also be used to make a model in the more traditional way of frames and outer skin...in this case the 3-D design is sectioned up, and printed off to the right scale. The frames etc are then cut by hand etc.
    You need to decide what material your model is to be made of, source if possible enough design information to get the model made, and source a model maker who is happy to work with the information and material you prefer....unless the model maker can prepare the design info himself of course. Dont forget that many professional model makers will be concerned with the intrinsic copyright in the original design. If its a one-off, just for you, there shouldn't be too much of an issue but if it was, say, a model that could be marketed, that is an entirely different scenario. Either way, good luck, and if it progresses, post up the pics.
  3. Longranger5
    Asia
    Thanks CODOG for your input.
    Could you suggest some forums where i could start?
    I plan to use the model for personal use and so dont see much of copyright issues. Even if there is, we could tweak the design slightly and ensure no problems.
    I am not aware of what material would be best and economical since i want a working model and would leave the model builder to decide that. I am open to ideas and flexible enough to get the job done. Im sure it would be atleast a year before i complete the project, but am sure it should be an exciting one. My idea is if i cant own that superyacht, why not own a working model of the original, the closest to experiencing it!!!
  4. wscott52
    wscott52 Senior Member
    SE Florida
  5. CODOG
    CODOG Senior Member
    There are so many Longranger5, I'm sure a bit of Googling will throw up plenty of choice. Its the same with actual modelmaking companies. Many sources in Asia by the way...very talented modelmakers out there.
    A selection of companies I've looked at before...
    http://www.yca-hk.com/yacht-model.php
    Although they seem to concentrate on display models, they may be willing to quote for an empty shell that can be adapted for RC . I stress that there are literally hundreds of similar companies around the world.
    Two things to note looking at that site...they have a pricing guide depending on size of model...they also list their requirements for what they need from you the client to be able to make the model. 3-D design info is a must, and I assume they then machine the tooling from this and make moulds for the major parts of the model.
    http://www.model-ships.co.uk/index.php/fuseaction/shop.category/categoryid/31
    And finally this one which looks very exciting indeed...
    http://www.captainsmodels.com/
    If I seem to be banging on about 3-D, machined / milled tooling, and GRP material, then I confess that this method of large model construction would be my personal choice for an RC model.
    By the way, have you seen the beautiful 3-D renderings of Amevi on here done by our very own Apache2k ?.....commissioning a similar 3-D model which could then be processed by a company similar to my links above isnt such a crazy idea.
  6. Longranger5
    Asia
    Thanks CODOG.
    Have got in touch with a few people to see where to start. Will post the progress over here to keep all informed.
