Click for Walker Click for Delta Click for Abeking Click for Ocean Alexander Click for Westport
Lincoln 430 engine design differences
Discussion in 'Chris Craft Roamer Yacht' started by raemore, Jul 3, 2010.
  1. raemore
    raemore Member
    roamer 64
    some 430's (older?) have the extra riser on the exhaust manifold some do not.
    can anyone shed some light on this???
    otherwise... these are great engines btw.
  2. ILELBOAT
    ILELBOAT New Member
    Starved Rock Yacht Club Ottawa, Illinois 61350
    Riser Hight
    The riser is to keep water out of the engine. when the designer caculated the water line and where the engine sat the hieght required to keep water out is in the hieght of the riser.
  3. raemore
    raemore Member
    roamer 64
    430 differences
    yes... thanks for the info.
    wasnt sure if the riser had any other functions other than to raise the water level height into the manifold.
    So as far as I can tell all 430 blocks, heads, etc are the same ?
    \alex
  4. Seafarer
    Seafarer Senior Member
    Hudson River
    That should be true for the marine engines. The MEL didn't change much over its lifetime, except for some displacement increases. The roadgoing engines had manifold changes and piston changes which should not have been reflected in the marinized variants.
  5. P Jardine
    P Jardine New Member
    Ontario Canada
    There are substantial differences in the years that the MEL 430 engine was produced. The heads, intake manifolds, compression ratios, carburetion, and cooling systems all changed within the 1958-1965 life of the 430.
    The 430HR Chris Craft was the earlier model by CC, the 431 reflected the cooling systems changes that CC did to keep the engine cooler when used in the bigger boats.
    In particular, the intake manifolds and heads do not interchange between years, since the port sizes are different.
