Click for Walker Click for Burger Click for Abeking Click for Burger Click for Westport
KVH vs Intelian, M7 replacement
Discussion in 'Electronics' started by Pascal, Nov 14, 2018.
  1. Pascal
    having an issue with a 9 year old KVH M7. Turned out to the slip ring in the base which can only repaired by the factory. Not just expensive but also at least 3 weeks downtime as it has to be shipped truck to CT
    Not sure about spending maybe $1500 on an almost 10 year old system
    Options are new KVH TV6 or intellian M6
    KVH is a little more expensive but installer says the new control box is gets hot and must be installed in air conditioned space. Apparently they build a lot of heat. He s replaces a few
    Anyone heard anything about that?
    Leaning towards the intellian.
  2. dennismc
    dennismc Senior Member
    Vancouver BC
    Have you researched "sea tel" had mine now for 12 yrs zero problems..
  3. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    My SeaKing RJ9818 went south about two months ago. Its was a 2007 model. My repairman stated I could have it repaired but that in another few months it would be useless. Something that Directv is doing with the signal. Make a long story short I purchased a Trackvision TV5.
    Did you keep the SeeKing dome. Have a customer that does not need H D TV. Bad motor on the vertical traveler.
    Commercial marine electronics in Pompano Beach, FL has tons of old stock of all sorts of electronics parts, try giving them a call. They cannibalize everything they take off and store it.
  6. CSkipR
    CSkipR Member
    Capt Ralph,
    Yes I have the whole unit. I'll give you a call Monday morning. Skip
