Click for CL Yachts 99X Click for Abeking Click for Abeking Click for Westport Click for Cross
Kiekhaefer Marine Race Engines
Discussion in 'YachtForums Yacht Club' started by Fishtigua, Mar 5, 2014.
  1. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    We have a pair of classic Kiekhaefer Big Block V8 race engines in the workshop. We are looking for one or two parts to make the pair complete.
    We need the mechanical pumps, 300psi fuel pump and a few other bits and bobs to make up a very rare pair.
    As you may remember, Carl K ran his race engine team in a very precise way, almost with military precision. No belt drives for him, direct driven only.
    If any members have a lead on where to find parts, we would be very pleased to hear about them. We managed to get some original stuff from a team in Abu Dhabi, but the parts seem to be drying up now.
    Thank you.
      10.4 KB
  2. travler
    travler Senior Member
    roche harbor wa
    engines
    do you no which pump? Do the pair have carbs or fuel injection? Are the engines 496's or 510 cubic inch. I might still have some stuff from when we raced an offshore boat.
    john
  3. Old Phart
    Old Phart Senior Member
    I dunno
    Do you have a pair of 6's or better yet, m8's to complete the package?
  4. Perlmudder
    Perlmudder Member
    Toronto/Crystal Beach
    I would try looking on offshoreonly. If someone knows of the parts or where to find them, that is where it will be. Good luck in the hunt
  5. Fishtigua
    Guernsey/Antigua
    Stupidly, I forgot to post a photo of the engine.
    May I say, it's on the loud side of being a bit shouty.
  6. travler
    roche harbor wa
    does the fuel pump have a 3 bolt pattern or a 4 bolt on the front and does it run directly of the cam with a square drive
    john
  7. K1W1
    That looks awfully like an automotive tranny on the ground behind that thing
  8. Fishtigua
    Guernsey/Antigua
    Yes, it's cam driven but not sure of the bolt pattern. Will check on Monday.
  9. CTdave
    CTdave Senior Member
    Greenwich CT/ Stuart FL
    I have completely lost track of him but Don Roberts had several of these engines (and LOTS of parts) sitting around for many years. He had a marine shop called "Connecticut Offshore" but that last time I had my eyes on the stuff was over 12 or more years ago. The shop is long gone but he had kept all the stuff through several moves.
    Don was involved with the Jessie James team but also worked on many others.
    If you can find him, I bet he will know where you can find exactly what you need.
  10. Anchored
    Anchored New Member
    Minnesota
    Have you tried Cobra power in Florida?
    Also, Mike Bontoft in Poole would be able to help as well.
    Jeff
  11. Fishtigua
    Guernsey/Antigua
    Thanks guys. We'll do some digging when the season quietens down a bit.
  12. NEO56
    NEO56 Member
    Miami
    Hi Fishtigua,
    This might be a shot in the dark, but I had a Client who worked as a design engineer at the "skunk works" at Mercury Marine. I would call Mercury and ask to speak with a design engineer...talk sweet to him...and he might be able to put you on to an untapped source. It's worth a few phone calls....hope that helps.
  13. Anchored
    Anchored New Member
    Minnesota
    And of course the system is a Lucas Kinsler, so they should be able to help as well.
    Lucas
    Jeff
  14. Trippin
    Trippin New Member
    Lexington, KY
    Not OEM
    6's and certainly M8's were not available as factory equipment back then. SSM3's possibly 5's were or the K600 coupled to the 468c.i. which is that very engine. The K6 eventually turned into the SSM6. I think the idea here is factory original.
  15. Fishtigua
    Guernsey/Antigua
    We are just happy to have one engine up and running, the other one is up in the loft in pieces. On the last boat, a dragster sprint boat, it was on a shaft.
  16. K1W1
    Fish,
    If you are serious about running these engines you can often find non engine driven pumps to do whatever task you require, you might need to add a Gen-set to run some though
  17. Trippin
    Trippin New Member
    Lexington, KY
    Sweet !!
    I'd love to see some video of that vintage thumper running....
  18. Anchored
    Anchored New Member
    Minnesota
    Will this suffice?
    Jeff
  19. NEO56
    NEO56 Member
    Miami
    Thanks Jeff, I really don't think there's a sweeter sound on this planet!
  20. K1W1
    This takes a lot of beating too.
