Click for Glendinning Click for Burger Click for Perko Click for YF Listing Service Click for Cross
Johnson yachts opinion
Discussion in 'General Yachting Discussion' started by FullPint, Jan 27, 2023.
  1. FullPint
    FullPint New Member
    Melbourne
    Hi, looking at buying a Johnson yacht. Options between 56-65 foot on the market. I previously had a Hatteras 48 CPMY. If you have owned a Johnson I would be interested to know your opinions on sea keeping, build quality etc. If you have knowledge comparing to a Hatteras that would be even better! Cheers
  2. Pascal
    I ran a 2003 70 Johnson skylounge for about 8 racking up thousands of miles up and down the east coast and the Bahamas. My personal boat is an old 53 Hatteras so how does a Johnson compare to a Hatteras? Not even close :)
    I remember the first time I crossed a small wake with the Johnson at an angle… the whole boat shuddered. If you just take a look at the bows you ll see why right away. The hatts have sharp deep entry whereas the Johnsons have a bloated fat bow. The upside is that the forward stateroom in the Johnson is huge with a centerline queen.
    the 70 I ran was a skylounge and top heavy especially with the tender and jet ski up top. Without stabilizers it was handful.
    definitely a boat you want to pick your days in open waters…
    quality wise it was ok. ER was very tight with the optional 3412Es. Systems were pretty well layed out and built. Not a fan of the aluminum fuel tanks outboard of the engines… Taiwan stainless steel leaves a lot to be desired. Be ready to buy Rust stain remover by the gallon :)
    Another issue of the 70 was the draft of just over 6’
    Performance was good… with the 1400hp 3412Es it would top at 31kts and cruise anywhere between 20 and 25kts burning about 85GPH at 21kts at 55% load
    amazing layout especially the huge aft deck and swim platform
    Altogether a good boat for protected waters. Ok for near coastal, if you don’t mind waiting for good conditions
  3. FullPint
    FullPint New Member
    Melbourne
    Thanks for that, really appreciated!
    Melbourne, Victoria??
    Yes, re-read that last line of that last post.
  5. Pascal
    Thinking back I remember a couple of rough times…. One was leaving the cape may canal and heading up the Delaware with 15/18kts on the bow. 4 hours of banging.
    another no so sweet memory was leaving Woods Hole into Vineyard Sound with three footers on the beam. Plastic latch on skylounge uline fridge broke and the fridge content spilled all over incl broken beer bottles.
    then was the time on the exuma bank between Norman’s and Nassau where one roll was so bad that it tripped the oil safety on the gen. And moved all the furniture across the salon.
    oh and that night approaching Nassau in mild conditions where the Ubolt on the jet ski ripped out along with a chunk of fiberglass and I had to secure it with lines while rolling back n forth.
  6. FullPint
    FullPint New Member
    Melbourne
    Yes mate, but we are looking for a boat for the Mediterranean. I had a Hatteras 48 last time but sold it about 2 years ago. So I’m looking for a boat for Europe that is a good sea boat, roomy and comfortable. I keep coming back to Hatteras. I like Princess too but again, have no idea what they are like at Sea.
  7. mapism
    mapism Senior Member
    Sardinia
    Am I understanding correctly that you are looking for a used boat to buy, with the plan to enjoy her in the Med?
    If so, you can do worse than looking at an Italian boat. I mean, when in Rome...!
    In the 55' to 65' bracket, I can think of at least a dozen of good builders (and several models for each of them!) worth considering.
    Depending also on your budget, which ultimately triggers the boat age, hence the models.
    If you don't mind sharing a ballpark amount, I'd be happy to name the better builders and models I can think of.
  8. FullPint
    FullPint New Member
    Melbourne
    If you could give a recommendation for the best of them say, top 5 that would be great. Around the 60’ range would be great!
  9. mapism
    Sardinia
    The Italian builders that I would consider the top five in this size bracket actually depend on the boat age.
    Which is essentially budget-driven, hence my previous question.
    But assuming, based on what you told so far, that you are looking at 20+ years old boats, some brands I would start with are (in no particular order):
    Sanlorenzo, Ferretti, VZ, Uniesse, DP, Antago, Posillipo.
    All of them had more than one model in the 55/65 size bracket, and of course the difference between the two extremes are somewhat substantial.
    Pick your poison!
  10. FullPint
    FullPint New Member
    Melbourne
    Thanks for that. I’ll have a good look!
  11. FullPint
    FullPint New Member
    Melbourne
    Thanks for that! I’m getting the picture!
  12. Brian G
    Brian G Member
    Destin, FL
    I currently own a 2003 Johnson 70 Skylounge that I've had for 5 years. This is my first and probably only motoryacht so I don't have a lot to compare it to as far as ownership but I did look at a lot of boats before making a decision.
    Strengths
    • Solid engines (Cat 3412e)
    • Beautiful woodwork - quality fit and finish
    • Great layout (3 staterooms forward and master aft)
    • Large aft deck where we spend most of our time
    • Enclosed flybridge which makes for very comfortable driving and includes Uline refrigerator and sink
    • High end galley components (Fisher and Paykel dishwasher, Jennair oven, Subzero refrigerator drawers, Uline wine cooler, etc)
    Weaknesses
    • Does not take beam waves well
    • Some components have been hard to source such as example Gewiss outlets/switches and Italian recessed lights
    The other boats I was looking at were Lazarra, Horizon and Monte Fino. My early research put Hatteras at the top of my list but in spite of its superior seakeeping reputation, I didn't care for the boxy exterior of the older models or the closed in feeling of the interior once I actually stepped aboard. To each his own, I guess. As Pascal has noted, I've just learned to choose my offshore days carefully. :)
  13. FullPint
    FullPint New Member
    Melbourne
    Thanks for the comments. It is really helpful. I’ve found there is always a compromise somewhere!
  14. Pascal
    Couple more things I remembered…
    window leaks: I’ve the 8 years I ran the boat we spent a lot of time fixing window and porthole leaks. And repairing the damaged wood…. Especially the front windshield.
    We also had to deal with a few exhaust leak in the fiberglass tube behind the cabinetry in the master. For some reason it would develop pin holes resulting in wet carpet. Had to cut numerous access holes in the back of the lower cabinet to get to the tube.
  15. Norseman
    Norseman Senior Member
    Palm Coast, Florida
    The most memorable event I remember from running a Johnson 70 some
    years ago, was the dishwasher came flying across the floorboards from Starboard to
    Port when we ventured out the cut from Port Everglades.
    It was a bit lumpy but not too bad, just a normal day in Florida.
    No damage done, we got it back in place and called a tech to secure it later the
    same day.
  16. FullPint
    FullPint New Member
    Melbourne
    Thanks for that. I had a hatteras before and the access was always great!
  17. FullPint
    FullPint New Member
    Melbourne
    That would have been annoying! I had my coffee machine come off the kitchen bench top when I forgot to secure it and somehow it miraculously didn’t break. Funny things happen on boats!
  18. mapism
    Sardinia
    She must have been a solid boat (and dishwasher too!), if nothing else... :D
    cognac likes this.
  19. Norseman
    Palm Coast, Florida
    Yeah, the boat was probably ok, but she wasn't commissioned right, there was a whole bunch of little things and some big ones as well, always work in progress.
  20. Pascal
    One of the worst mistakes on the one I ran was that they forgot to put a limber hole in a frame right before the transom where the stern thruster was installed. After a few months bilge water rose and drowned the thruster motor…. Never bothered fixing it as access was awful. Who needs a stern thruster on a twin diesel anyway. When the boat sold, I made sure the broker didn’t mention the stern thruster to avoid a post survey adjustment :)
