Click for Abeking Click for Burger Click for Glendinning Click for Ocean Alexander Click for Northern Lights
Interior wall vinyl maintenance/repair
Discussion in 'Carver Yacht' started by mike benner, Mar 23, 2018.
  1. mike benner
    mike benner New Member
    Central Florida
    Any tips for re-stretching or replacing sagging wall vinyl in 90's model Carvers? It appears to be a common problem.
  2. Poppa John
    Poppa John New Member
    Naples Florida
    It may have been installed using contact cement. Try applying heat, using a hair dryer on low setting. Keep moving it around to avoid burning. Then press by rubbing with your hands. This should reactivate the glue. Good luck.
  3. mike benner
    Central Florida
    Thank you, I'll give it a try
  4. Poppa John
    Naples Florida
    Your welcome, let us know if it helped.
  5. Capt Ralph
    Some material coverings had a mat between the finish treatment and the bulkhead. The finish fell like ole Rose; https://en.wikipedia.org/wiki/Mary_Millar
    You may not get enough glue in between the bulkhead and the finish cover.
    You may consider a new bulkhead cover entirely for your taste.
  6. mike benner
    Central Florida
    If this fix doesn't work, I'm considering replacing with Teakwood film
